How To Clean the White Stitching on the seats?
Old Sep 16, 2011 | 12:45 AM
DiasG's Avatar
DiasG
Hey guys my white stitching on the seats is now dark gray!! and i was wondering if anyone knows a good way to clean them without damaging the leather seats? If anyone has tried something that worked please let me know thanks
Old Sep 16, 2011 | 03:56 AM
adroitcaptor's Avatar
adroitcaptor
PM Detailed Image; he is on the 'Car Care & Detailing' forum. The guy is way professional, responds quickly, and instead of just giving you an answer, he explains himself. Some of the best customer service you can get IMO.
Old Sep 16, 2011 | 09:16 PM
DiasG's Avatar
DiasG
Old Sep 17, 2011 | 12:01 AM
DiasG's Avatar
DiasG
thanks i just sent him a PM !
Old Sep 17, 2011 | 02:18 PM
08g37's Avatar
08g37
Why dont you let us know what he said that wr all can know if we have the same promblem
Old Sep 17, 2011 | 05:45 PM
amf25's Avatar
amf25
+1 here too thx
Old Sep 17, 2011 | 06:24 PM
jjasonSU's Avatar
jjasonSU
Soft Toothbrush,
Plastic cup w a couple drops of dishwashing liquid.
Then blow dry w compressor air.
Then Condition leather
Old Sep 18, 2011 | 07:14 AM
TOGWT's Avatar
TOGWT
Leather stitching is usually cotton and nylon mix, nylon is attacked by solvents, they melt it and weaken the threads. An oil-based product will attract abrasive dirt / grit and permeated the leather via the stitching, the oil will soften the leather, and the abrasive dirt plus friction may cause the leather to tear and / or the stitching to fail. Do not use harsh solvent-based cleaners as this may cause the stitching to fail over time
Stitching is somewhat friable if subjected to excessive abrasion. Bearing this in mind the cleaner and applicator ( a semi-soft toothbrush is ideal) needs to ‘do the work’ without relying on excess friction
a) Clean stitching using a medium / hard horse hair brush, a toothbrush or a sponge, spray and work the aqueous (water- based) cleaner into a foam or use; don't spray on the wheel, spray on the brush, constantly rinse the brush in clean water, remove cleaner by rinsing with clean water.
b) Use an aqueous (water- based) foaming cleaner; Leather Masters™ Foam Cleaner, shake aerosol thoroughly and then lightly rub surface and immediately wipe with a terry towel to remove excess moisture. You may need to repeat this process.
Once the stitching and the seating surfaces are clean apply Leather Masters™ Leather Protection this will help to keep the stitching clean and inhibit the ingress of dirt and soil
4DRZ
Midwestern
16
Dec 4, 2015 01:28 PM
User 122320
Buying & Leasing
Oct 15, 2015 01:47 PM
4DRZ
Sep 22, 2015 11:11 PM
Cmedlin96
Sep 20, 2015 11:09 PM
xpcgamer
Sep 7, 2015 07:10 PM
