Scotch Tape Gunk
Old Jun 21, 2008 | 03:06 AM
symalik's Avatar
symalik
Scotch Tape Gunk
So I left some (alot) of scotch tape on my car for like 2 days by mistake and when I took it off, the glue stuck to the car.... any idea/products/tips to clean that off? Or should simple goo gone should work?
Old Jun 21, 2008 | 03:08 AM
gmlee86's Avatar
gmlee86
Goo Gone should be fine if you don't rub it too hard with your finger since it'll take off clear coat
Old Jun 21, 2008 | 03:09 AM
SpecC's Avatar
SpecC
1. try a 50/50 isopropyl + water mixture
2. quick detailer
3. clay bar
if that fails, i think polish is needed
Old Jun 21, 2008 | 11:11 AM
xref's Avatar
xref
why did you use scotch tape? you're supposed to use painter's tape.
try meguiar's quick detailer.
Old Jun 21, 2008 | 11:45 AM
J.Oh's Avatar
J.Oh
WD-40 just rub with your finger after spraying the effected area
Old Jun 21, 2008 | 01:33 PM
symalik's Avatar
symalik
Because It was raining and that's all I had, I switched it to painted tape as soon as I could but it was too late.
symalik's Avatar
symalik
Isn't that bad for the paint?
Old Jun 21, 2008 | 02:05 PM
wrathletik1's Avatar
wrathletik1
3m adhesive remover, aerosol can.
Old Jun 21, 2008 | 02:09 PM
Don@Migliore's Avatar
Don@Migliore
2. quick detailer
3. clay bar
This man has it spot on . Please don't use WD40 on your paint!
Old Jun 21, 2008 | 04:18 PM
symalik's Avatar
symalik
Thank you, will try his method today or tomorrow morning.
Old Jun 22, 2008 | 11:20 AM
fkat's Avatar
fkat
Unless it's old and adhesive has bonded with the surface and changed its form to solid you should try this. Take another scotch tape and put it over the remaining adhesive. rub it gently so the two adhesive surfaces bond together. then peal the tape off. you should start to lift it off the surface. Repeat this until you get rid of all. You may need to change the tape to work with fresh set after few tries.
HTH
Old Jun 26, 2008 | 06:51 AM
Concours Finish's Avatar
Concours Finish
2. quick detailer
3. clay bar
What he said.
Victory
17
Oct 27, 2022 03:45 PM
37
Oct 17, 2020 11:12 AM
obg376mt
Intake and Exhaust
16
Aug 9, 2017 08:28 PM
User 122320
Sep 25, 2015 08:10 PM
cshawsg37
Sep 25, 2015 05:33 PM
