how can i repaint touch-up paint?
Old Mar 14, 2008 | 09:26 PM
Loi's Avatar
Loi
i smurred and made a mess. how can i somehow remove the touch up paint?
Old Mar 14, 2008 | 09:29 PM
speedracer g37's Avatar
speedracer g37
you can try wax. if that doesnt work and the paint has dried, try a very small amount of nail polish remover. if you rub with nail polish remover, you will haze the paint a bit, but you can buff it out.
Old Mar 14, 2008 | 09:33 PM
Loi's Avatar
Loi
sounds risky but ill prolly have to try. thanks bro
Old Mar 14, 2008 | 09:58 PM
RedG37SNC's Avatar
RedG37SNC
You can try using detailing clay. I'd also suggest a different touch up paint like http://drcolorchip.com/, no problems with over doing it.
Old Mar 14, 2008 | 10:29 PM
speedracer g37
your factory paint is chemically pretty tough. you can also try lighter fluid or paint thinner, but you are going to have to be very careful, no matter what solvent you use. i owned and operated a bodyshop for six years and i can tell you that you will not do real permanent damage unless you get careless or overzealous. take a hand towel, or a shop towel and slowly/gently (with just the tip of your finger covered by the towel) rub off only the touch up paint. most likely, you will get a little hazing, but polish and wax will get the haze off.
Old Mar 16, 2008 | 09:35 PM
Loi's Avatar
Loi
thanks bro.. i got some of it off today by putting on a wet layer and rubbed it off. i ima try to get the rest off with a thin brush and acteone
Old Mar 18, 2008 | 11:05 AM
gDriven's Avatar
gDriven
has anyone tried langka with good results? I put some on and it looks horrible.
Old Mar 18, 2008 | 02:02 PM
jdmalltheway's Avatar
jdmalltheway
that langka stuff works better than regular touch up, but not perfect. Their videos made it look much better than real life.
Old Mar 25, 2008 | 10:11 AM
mhfnet's Avatar
mhfnet
Lacquer thinner works the best as it doesn't effect the tougher factory paint but easily removes touch-up paint. Also great for removing stuff like tar and cleaning the spot before touch-up.
Old Mar 25, 2008 | 10:13 AM
LAG37's Avatar
LAG37
so what happened Loi?
GeezerB
Car Care & Detailing
12
Jan 23, 2017 07:00 AM
ck1109
Oct 15, 2015 11:06 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
Chris_M
Sep 25, 2015 08:38 PM
