Project Panda
Old Mar 5, 2020 | 04:07 PM
  #136
BULL's Avatar
BULL
Moderador
Originally Posted by projectpanda13
Its a sheet I found at Home Depot. I'm not very low, but I use to live in a neighborhood that had massive speed bumps, and this has been a life saver.
​​​​​​ I made a template from a piece of cardboard that I want to recreate in metal.
Cant justify spending more than $100 for an undertray.
Old Mar 5, 2020 | 04:16 PM
  #137
projectpanda13's Avatar
projectpanda13
I completely agree on the cost. I want to say I for sure stayed under $40, possibly in the low $30 including the retaining clips i got at Autozone.
Old Mar 10, 2020 | 07:29 AM
  #138
projectpanda13
Exhaust is almost done. I love how its tucked and sits above the brace.
Old Mar 11, 2020 | 08:16 AM
  #139
projectpanda13
Z1 Motor mounts came in. These will go nicely with the transmission mount I already have.
Old Mar 11, 2020 | 12:49 PM
  #140
PNW_IPL's Avatar
PNW_IPL
definitely good mod. No added nvh either. That single on the other hand. Get ready to hear the VQ gods
Old Mar 11, 2020 | 12:55 PM
  #141
I think you're right, that the motor mounts are relatively light on NVH. Certainly when compared to Z1's poly transmission mount. With hindsight, I should have done the motor mounts first. There are moments when I think of going back to the stock transmission mount. It's been a few years, and I've been wondering if I'd like less rumble through the floorboards. I think my OEM mount is still up in the attic.
Given that the OP already upgraded his transmission mount, then yes, he really won't see much of a change in NVH.
Here's an old pic, with the OEM shifter, too. Panda, if you still have it, I'd say hang on to your OEM mount, just in case.
Old Mar 11, 2020 | 01:09 PM
  #142
PNW_IPL's Avatar
PNW_IPL
I too have been thinking of going back to oem trans mount
Old Mar 12, 2020 | 08:27 AM
  #143
projectpanda13
I don't mind the vibrations. I remember reading somewhere that the mount can be spaced out in a certain way to lessen the NVH. The information was stated by someone at Z1. I'll try to dig it up and try it then report back.
Old Mar 17, 2020 | 05:58 PM
  #144
projectpanda13
Shawn made this exhaust at my request. It’s a 3.5” single exit exhaust with a vibrant resonator and helmholtz chamber. Totally weight came out to 27lbs.
my ideal for this was mainly preparation for when I go boost. I know 3” have worked but wanted to see how things would be if I had something in between a single 3” and a dual 3”.
Old Mar 19, 2020 | 03:26 PM
  #145
BULL's Avatar
BULL
Moderador
Gotta post a sound clip once installed.
Old Mar 19, 2020 | 03:46 PM
  #146
They sure did polish the heck out of those pieces.
Looks like a Meisterschaft component, the way bends are stepped into with incremental pieces in the curve. There's probably a welding term for that.
Anyway, it's pretty. Not really into burnt Ti tips, particularly if the burn is competing for space with the logo, but can't deny they look nice. And don't know what to think of the flat cap Helmholtz chamber. I'm curious to see what that looks like on the car.
Old Mar 23, 2020 | 11:36 AM
  #147
projectpanda13
FINALLY! I just received my parts from Rej at Rabbit Hole Motorsports. It took a while as he had to redesign a few things, which is understandable. I am still waiting for the throttle bodies to be shipped to me as the final pieces.
As soon as I have these parts on, I'll be pulling off my EPS and CFM Performance ported upper and lower manifolds. Probably going to want to sell those items together as it was ported together.
In terms of gain, I'm honestly not looking/expecting much if any gains. Matt had a set on his car that didn't produce any gains. I mean, there's only so much air that can flow in N/A form, especially since I'm not built/stroked or anything. As long as I don't loose any power, mid or peak, I'm good. I plan is that this will help when I go boost.
Old Mar 23, 2020 | 11:42 AM
  #148
projectpanda13
Hey Bull, I definitely will do. I am hoping I'll get my car back sometime next week from the body shop.
I'm a fan of Shawn's work, though I don't know much about welding. I really liked his original 3" super single he made for the sedan, so I asked him for this. I do feel there is a lot going on at the tip. I slightly feel I should have gone with a more subtle style. but its ok. The helmholtz he had on his original single helped a ton with the rasp vs those that didn't have it. We'll see how this will sound, considering this is also a 3.5"
Old Mar 24, 2020 | 09:37 AM
  #149
backman_66's Avatar
backman_66
I call dibs!
Old Mar 24, 2020 | 09:55 AM
  #150
Found it. The welding term is "Pie Cutting". Also "Lobster Backing", but I think Pie Cutting is more common.
The reasoning is that pie-cuts are stronger than pipes which are stretched and bent. Also, pie-cuts maintain a consistent radius.
The whole steam punk look is just the icing on the cake. Not everyone's cup of tea, but I think it looks cool.
