ttv36 - 700+ rwhp Sedan Build Thread
Old Oct 6, 2015 | 07:57 PM
  #301
2GoRNot2G's Avatar
2GoRNot2G
Originally Posted by tonyHTX
Ok back to my adventures which lead up to the dyno..
One thing I forgot to mention in the most recent posts is that the used transmission I got from the salvage yard, which was put in with my new clutch, actually grind 5th gear as well!
I was told it had 'only 40k miles' - another testament to the 'do it right the first time' lesson that all us modders constantly struggle with.. Luckily the salvage yard would take the transmission back, however the time and money spent on installation and removal is lost..
I used a bit of my time delivering transmissions here and there to ensure things kept moving along smoothly.
My original 99k mile transmission was delivered as a core:
Then the used transmission was returned to the salvage yard:
And finally the expensive 'do it right the first time' lesson that I consistently struggle with (major props to David for hooking it up!) :
Pretty much a brand new car now:
Since I didnt 'need' my car back right away I decided to finally go ahead with the install of my CJ Motorsports Stage 3 RFS.
Turned out this was one of the best decisions I have made, because when we pulled the plugs one of them looked like this:
I was waiting to install the upgraded fuel system before I switched to E85 and this sign was also added to the list of reasons.
I always wanted a peep hole in my cover:
The beautiful CJM in tank twin fuel pump module:
Only to be not seen:
Ron ended up modifying some of the design and not using most of the hard pipe, but overall it came out quite clean:
The old AAM Stage 0 RFS:
That leads up to the last video where the car was filled with E85 and put on the dyno:
I picked it up the next day and did what anyone would do:
I got owned by a fast evo:
Second 1/4 Quarter Mile Test - Twin Turbo V36 (TT V36) Infiniti G35 / G37 Sedan 4k - YouTube
Second 1/4 Quarter Mile Test Exterior - Twin Turbo V36 (TT V36) Infiniti G35 / G37 Sedan 4k - YouTube
I am 289 on the left:
And that's all for now, hopefully I will get to go back with some better tires soon! Now with 9.5 mpg:
Wow! That's a lot of work for a new tranny, Tony. I think your next vehicle should be a truck. ;-) I love my Ram 2500.. It's great for hauling parts!!!
And nice time slip! That's more like it! Throw on some drag radials and you should drop those 60' times enough to break into the 11's for sure!
Old Oct 7, 2015 | 12:06 PM
  #302
ttv36's Avatar
ttv36
Race, repair, repeat.
I went back to the strip this past Friday to try to break 11s. Only thing I broke was another axle..
Old Oct 7, 2015 | 04:51 PM
  #303
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Good excuse for upgrade axles! (hope you're back in the seat soon)
Old Oct 7, 2015 | 05:17 PM
  #304
ttv36's Avatar
ttv36
The DSS axles are on order, but they are made to order 3-4 weeks. I am in the process of getting yet another OEM one for the meantime..
Old Oct 7, 2015 | 07:31 PM
  #305
2GoRNot2G's Avatar
2GoRNot2G
That just means your making traction, Tony! And like Mike said, also makes for a good excuse for upgraded axles.
Sounds like a fun day at the junk yard is in your future! Wish I lived closer so I could join you!
Sorry to hear about the broken axle, but you'll be back up and running and stronger than ever before you know it.
Old Oct 8, 2015 | 10:42 AM
  #306
warpeacelove's Avatar
warpeacelove
The Driveshaft Shop | NISSAN 2009- 370Z / G37 1200HP Pro-Level Axles - 370Z / G37 - Nissan - Import Axles
Old Oct 8, 2015 | 01:38 PM
  #307
ttv36's Avatar
ttv36
^ Yes those are the axles that are on order. Again, they are made to order which is 3-4 weeks.
Old Oct 9, 2015 | 12:37 PM
  #308
2GoRNot2G's Avatar
2GoRNot2G
Nice! Those look similar to the axles on my S2 convertible.
Is your car down until those come in or were you able to find another stock replacement for the time being?
Old Oct 9, 2015 | 03:47 PM
  #309
ttv36's Avatar
ttv36
I found a stock one but haven't put it in yet. I actually sold my daily and took the G to work today with broken axle and all. Thank you LSD!
Old Oct 9, 2015 | 06:29 PM
  #310
That's awesome!
Old Oct 9, 2015 | 06:33 PM
  #311
Redfire32's Avatar
Redfire32
Ginger ninja
This is the serious racecar bunch I've only recently realized this. Got some serious build thread reading to do.
Old Oct 9, 2015 | 11:01 PM
  #312
ChinkyChoy's Avatar
ChinkyChoy
too much powa
Old Oct 16, 2015 | 11:30 AM
  #313
What's with the SN change?
Old Oct 16, 2015 | 04:20 PM
  #314
ttv36's Avatar
ttv36
^ I've started using the SN everywhere else so I figured to change them all.
Old Oct 21, 2015 | 01:19 PM
  #315
ttv36's Avatar
ttv36
Haven't been doing too much lately besides driving and maintenance.
As mentioned above I broke an axle at the track 3 weeks or so ago. The day after I noticed that the axle wasn't the only thing that broke. I guess QuikSteel just wasn't enough to hold the shroud in place:
Took things apart and epoxied the shroud back in place after rebaking the headlight again:
Then replaced the axle since the car was on stands:
Sold my E63 to drop the car note so the G went back to daily duties while I looked for a cash car:
Cash car found, it's the new daily so no mods..
But the tires were bad and I got wheels and tires for less than buying a set of new tires..
This past weekend was Wekfest so I went to support Houston's Mayday Garage who hosted the premeet:
Then showed during Wekfest:
Took home this little guy:
Truly am humbled that the vision is appreciated since the car isn't slammed/stanced like many of the other cars that were showing. Probably will be my last car show for awhile as 2016 is when I hope to really beat the **** out of the car on the track.
