My Mod + Dyno Log
Old Dec 26, 2014 | 12:07 AM
  #361
kdawg8526's Avatar
kdawg8526
notice any rasp? and can you make a video sometime i would love to hear how it sounds
Old Dec 26, 2014 | 04:39 PM
  #362
alfredo24pr's Avatar
alfredo24pr
I really can't hear it rasp that much. I tried to take a driving video but failed badly. Lol.
Bought some goodies for my Sony action cam to reduce the wind noise. Will do a reshoot when I get them.
Old Dec 27, 2014 | 02:49 AM
  #363
kdawg8526's Avatar
kdawg8526
have the same problem with my gopro what did you get to help with sound
Old Dec 27, 2014 | 11:26 AM
  #364
alfredo24pr
For the GoPro, they have the "Rabbit Fur" that acts as a windshield to reduce wind noise. You can find it easily on ebay. It's an easy plug and play.
For my Sony HDR-AS100V, you can see the two microphones in the front, which is horrible for filming in the direction you are heading towards.
So, I had to buy that Rabbit Fur, but will be cutting it, in order to cover the 2 microphones. This should help a lot. We'll see...
Old Dec 27, 2014 | 02:40 PM
  #365
dtea54's Avatar
dtea54
Just wondering what your using to mount the action cam on your car ? I have a dash crab but it seems suspect to me.
Old Dec 27, 2014 | 04:50 PM
  #366
alfredo24pr
This mount (Windshield/Dash Flexneck Camera):
I mount it either on the inside of the driver's side window at an angle, or on the moonroof from the exterior. I don't like to mount on exterior of the car because it doesn't feel safe, so when I mount on moonroof, I tie a little string around it. That way, in case it falls down, it won't go flying off. However, the video was still shaky since the mount is a bit long. I also have a short mount that works as a suction, which might work better for exterior moonroof mount. I'm still figuring it out and testing for a good view and sound.
Old Dec 31, 2014 | 12:19 PM
  #367
kdawg8526's Avatar
kdawg8526
haha thats what i do too tie it with a wire better safe than sorry
Old Jan 19, 2015 | 09:44 AM
  #368
alfredo24pr
Back at the shop for NST pulleys install...
Also, testing out action cam for exhaust sound. Don't have a co-pilot so I can't get different angles on the shootings.
Old Jan 19, 2015 | 10:30 AM
  #369
WillCo1's Avatar
WillCo1
Tell your job you need to take some time off so you can update us with video's, new dynos, pictures, write-up's etc.
We are counting on you.
Old Jan 19, 2015 | 05:58 PM
  #370
alfredo24pr
NST Pulleys Review
lol. I don't have a job at the moment. I'm a full-time student, thankfully.
Now about the NST Pulleys:
The install seemed to be a bit of PITA. The problem seemed to be removing the crank bolt.
As for the butt dyno, the throttle is definitely more responsive. And about the gains, we will see about that on the dyno (soon).
Would I recommend this mod?
I still haven't tested it enough (dyno, track, etc.), but for now I would say that this mod is nice for those of you looking to squeeze every last bit of N/A power. If you are planning on FI or trading in the car soon, then I would not recommend.
Old Jan 20, 2015 | 11:26 AM
  #371
alfredo24pr
Here is a short video of MXP RTPs paired with ARK.
I know video could use some improvement. Still working on getting the best sound.
Old Jan 20, 2015 | 11:27 AM
  #372
This video is private.
Old Jan 20, 2015 | 11:30 AM
  #373
alfredo24pr
woops.
Fixed
Old Jan 20, 2015 | 03:16 PM
  #374
alfredo24pr
Here is some info about the weight differences of the NST vs. OEM pulleys.
That's 1.23 lbs vs. 4.66 lbs for the crank pulley
and 0.18 lbs vs. 0.52 lbs for the alternator pulley.
Old Jan 20, 2015 | 08:51 PM
  #375
RexHavoc's Avatar
RexHavoc
Wow, that's a significant difference. Any perceived issues with balance?
