My RB Project, going all in!
Old Dec 31, 2012 | 10:05 AM
  #196
G37Sam's Avatar
G37Sam
Originally Posted by kpjc4eva
Are you planning to find and buy a N1 block?
Not really, RB30 > N1 Block.. check out what RIPS did with their RB30 The block is far from being the limiting factor in my build.
Originally Posted by Can'tGme
I used to own a 350Z and I've seen numerous awesome builds/swaps over on MY350z.com from turbo LSX to 2ZJ swaps; but this RB swap has gotten me more excited and jealous than any other swap I've seen!
Thanks for the kind words man
Old Dec 31, 2012 | 04:40 PM
  #197
kpjc4eva's Avatar
kpjc4eva
Oh you got the rb30. oops. Have you thought about there super charger , twin turbo set up? I'm going to find the link. The set up is dope.
Old Dec 31, 2012 | 05:04 PM
  #198
kpjc4eva's Avatar
kpjc4eva
http://insertcointobegin.com/wp-cont...Skyline_1_.jpg
I cant find the link, but here's the picture of it. I'm 99% sure its by rips but that set up would blow people out of the water. Have you encountered that one Nissan SUV beating almost every car where your at? Or I think it was where your at. It could be Bahrain I'm not to sure.
Old Dec 31, 2012 | 06:45 PM
  #199
ashmostro's Avatar
ashmostro
That hole shot was ungodly!
Old Dec 31, 2012 | 07:33 PM
  #200
gtslo88's Avatar
gtslo88
Am i the only one that noticed the car above is sponsered by Cocaine?
Old Dec 31, 2012 | 08:15 PM
  #201
Elperuano's Avatar
Elperuano
Cocaine is a helluva drug!
Old Jan 1, 2013 | 02:13 PM
  #202
G37Sam's Avatar
G37Sam
Now that's just crazy!!
Update 31-12-2012
My shift **** is here
That sway bar is a little too close to what looks like an idler pulley, wonder if it can be relocated. Bummer I was hoping to go with thicker sways.
Customized adapter for the clutch pedal
And another one for the accelerator
Here's what it all looks like, will have to get the clutch pedal aligned later on!
Old Jan 1, 2013 | 03:38 PM
  #203
ashmostro's Avatar
ashmostro
Can't you fab up a couple spacers to sandwich between the U-brackets and the frame where the front sway mounts up? Would need longer mounting bolts but it should work...
Old Jan 2, 2013 | 01:24 AM
  #204
G37Sam's Avatar
G37Sam
I guess I can try that, I would probably need to use a similar spacer for the swaybar bushing too?
Old Jan 2, 2013 | 06:44 AM
  #205
ashmostro's Avatar
ashmostro
Well, what I was thinking was if you fab up a couple flat one-piece spacers with the same footprint as the whole bracket+bushing assembly then you would be covered. The frame rail mounting face IIRC is just a flat. Even if it's not, just following the countour would accomplish the same thing.
Basically, I would expect the outline of the spacer to be shaped like a large pill, if that makes sense?
Old Jan 7, 2013 | 09:10 AM
  #206
G37Sam's Avatar
G37Sam
I haven't been to the shop lately, but we're hoping to start wiring the Adaptronic ECU sometime this week.
For now, here's a shot of my twin in-tank fuel pumps
Old Jan 7, 2013 | 09:40 AM
  #207
ashmostro's Avatar
ashmostro
Niiiice! RB won't ever be starved for the go juice!
Old Jan 7, 2013 | 08:56 PM
  #208
RISKY GUY's Avatar
RISKY GUY
Looking good Sam, nice progress.
I'm seriously impressed with the build.
Your gonna hurt some feelings with that monster.
Old Jan 7, 2013 | 10:15 PM
  #209
MACS's Avatar
MACS
I'm not even gonna ask how much you've invested.
I can't afford it.
But I CAN live vicariously through your pictures... keep 'em coming!
Old Jan 8, 2013 | 04:16 PM
  #210
G37Sam's Avatar
G37Sam
Update 08-01-2012:
Great news! The car was started to check for leaks, minor leak in the turbo oil feed was fixed and MAN did it sound like a monster. Stay tuned for video's If everything goes as planned she should be going for ECU wiring & exhaust fabrication tomorrow. Fingers crossed. Here are some pics for now.
Oil cooler is in
OEM wiring with ignition system
Pedals are in and functioning properly!
Close up on the accelerator pedal, was a b!tch to get right the mechanic tells me
