Special HKS HIPERMAX III Adjustable Coilovers, special offer!
Feel like upgrading the suspension on your G37? HKS HIPERMAX III adjustable coilover system is the way to go! These bad boys are very comparable to KW Variant 3. With a variety of ride height settings to select from, you can get any look you're looking for, all while not sacrificing comfort, and increasing the handling performance of your ride.
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
In addition, the Hipermax III is shock-body adjustable (most applications) to allow vehicle height adjustment without affecting spring rate and piston stroke. With the Hipermax III’s range of adjustability, precise corner balancing can be achieved. Chrome-plated cylinder shafts provide excellent durability and newly-design rubber upper mounts reduce harshness.
Quality you can see!
PM me for best offer! Cheers
!Trending Topics
Falker11
Jan 11, 2016 02:22 PM
