Help Brake Pedal not returning Fully after emergency stop.
Old Sep 25, 2017 | 03:59 PM
Lowton's Avatar
Lowton
I had a person pull out in front of me, causing me to slam on the brakes. After that the car had no power like it was in a limp mode. (No CEL or other lights on) After tons of searching internet and the forums, I checked and sure enough my brake lights are on, so car thinks I am hitting the brakes while driving, reducing power. If I hold the pedal up, power returns. The pedal feels "loose" at the top. Is there an adjustment to bring the pedal up to contact the brake light and other sensor, it seems there are two switches at the top, unsure if either are being contacted. I find it hard to believe that i could break or bend something by slamming on the brakes. It does look like there is an adjustment nut on the shaft to the booster, Was hoping to find an easy fix. Thanks for any help. Oh, 2013 G37xS sedan.
Old Sep 25, 2017 | 05:49 PM
Surfnazi's Avatar
Surfnazi
Your abs system locked up unplug the battery for 30 mins should clear your issue
Old Sep 28, 2017 | 04:04 PM
Lowton's Avatar
Lowton
I wish that is all that is necessary, I can physically pull Up on the brake pedal and the brake lights turn off and cruise works, when I let go it falls down a fraction of an inch, but disconnects from switches and falls back into the low RPM, like I am pressing brake and gas. I am hoping there is a adjustment that can be performed to bring pedal back to top when released or maybe something is out of place, it looks fine, just a bit of slop at the top
Thank you
Old Jan 21, 2020 | 03:56 PM
SrtUltr's Avatar
SrtUltr
Thank you
Same exact situation, same make model year, happened to me this morning. Any updates on a fix?
Old Jan 21, 2020 | 04:10 PM
Lowton's Avatar
Lowton
nothing official. But I was able to add some pads to spot on pedal so have been able to drive. Recently though I have to lift on pedal for cruise control to work. I did find the full service manual online and there is a procedure to adjust pedal height and slack as well as a tolerance measurement. Just haven’t had time or weather to climb under dash.
Old Jan 21, 2020 | 05:15 PM
SrtUltr's Avatar
SrtUltr
Thanks for the tip about adding some pads I also picked up a new brake pedal switch. But I think you are correct in that the pedal may need a mechanical adjustment.
Old Jan 21, 2020 | 07:49 PM
SrtUltr's Avatar
SrtUltr
SOLVED
Looks like replacing the brake pedal switch fixed the issue. The brake pedal no longer feels loose, car is out of limp mode and the brake lights are functioning correctly.
To speculate on what I think happened, after slamming the brakes as hard as I did I think I may have knocked the brake pedal switch down a little bit based on how its installed. The switch installs like a turn signal bulb, insert the switch then quarter turn to lock down. I made sure to pull the switch against the bracket surface as tight as I could before turning it to lockdown. You may possibly be able to use the OEM switch by removing it and reinstalling it close to the bracket surface to get rid of the pedal play.
Noddy11
Nov 17, 2025 02:40 PM
R2-D2
Jun 8, 2018 02:27 PM
ZL1Gimpelson
May 8, 2018 01:38 PM
TheLocNar
Feb 8, 2018 07:25 PM
CougarRed
Apr 11, 2013 08:30 AM
