Help BRAKE/Slip/ABS aaaand Squishy pedal
Old 02-07-2018, 10:17 PM
TheLocNar
TheLocNar's Avatar
On my way home from running errands. Run out to the car, put foot down on brake to start the car and I hear/feel a *CLUNK* and the pedal hits the floor. All 3 of the warning lights are on. Made it home going slow. Was hoping it was just low brake fluid (it was indeed a little low), so I added more. When car is off, brake feels as it should, but as soon as I start the car, the pedal hits the floor without much effort. Master cylinder perhaps? Getting towed to dealer (eh) in the morning.
2010 G37xS just short of 80k miles, and sport brakes that were installed a few years ago.
Old 02-07-2018, 11:10 PM
Received 4,941 Likes on 4,174 Posts
Keep us posted on what you find, hopefully it's an easy solution.
G/L
Old 02-07-2018, 11:20 PM
TheLocNar
TheLocNar's Avatar
G/L
Will do. Given the mileage, I wouldn’t be surprised if it’s the brake booster/master cylinder. I just went out to the car. Before starting, the pedal was firm as it should be. Once started, easily hits the floor. Turned car off and no change. I’ll kick myself if it’s something simple like air in the system. But I just don’t have the ability right now to check. Until tomorrow!
Old 02-08-2018, 12:54 AM
JSolo
Just say no!!!!!
JSolo's Avatar
Last time I experienced this it was a blown brake line on a different car. However, if you have no external leaks and only happens when the engine is on, then it's an internal leak and as mentioned, the mc or booster. I do recall reading some other reports here of failed brake boosters.
Old 02-08-2018, 04:08 PM
TheLocNar
TheLocNar's Avatar
Update: Front passenger brake line was shot and front drivers side is on its way out. Need to be replaced of course. And of course they don’t have them in stock so they have to order. Got me a QX30 loaner.
Old 02-08-2018, 05:23 PM
JSolo
Just say no!!!!!
JSolo's Avatar
It's pretty rare for a line to fail, even in this area. Don't recall other posts about such an issue in the time I've been on here.
Be glad it's not the rear lines. More of a headache to replace.
Dealership too lazy to bend their own lines? Which dealer is this if you don't mind sharing?
Old 02-08-2018, 05:32 PM
TheLocNar
TheLocNar's Avatar
Fields in Glencoe. I have no reason to not believe them.
Old 02-08-2018, 05:44 PM
JSolo
Just say no!!!!!
JSolo's Avatar
I hear you. Did they show you the failed/failing lines? I've seen failed lines but wonder what one about to fail looks like - bulge maybe?
Be prepared for your bill to increase. It's possible other things will get broken in the process of removing the failed line(s). Did they try to sell you on replacing all the lines? It might be something to consider if you plan on keeping the car long term. Dealership may not be the cheapest place to do this but something to think about.
Old 02-08-2018, 07:25 PM
TheLocNar
TheLocNar's Avatar
Saw the lines. One about to fail had cracks. They said the rear were still good. No upsale there. I’m having them drain/fill the power steeriing fluid and 7AT fluid as well (my request). Car is there, might as well. $$$ but whatever. Just not in the mood to order all the fluids myself and wait at home on delivery day, then go to the independent shop I’d normally go to in another week or two (he’s always super busy).
Planning on a new car in 2020. This should tide me over until then.
Ryus
02-07-2018 07:21 PM
SRG
Photoshop
93
04-09-2014 06:33 PM
alexfair
General Tech Questions
04-02-2008 12:31 AM
Quick Reply: Help BRAKE/Slip/ABS aaaand Squishy pedal
