handling help, need suggestions
Old May 18, 2015 | 06:13 PM
squarehead's Avatar
squarehead
i've been working on tightening up my handling.
so far i've done:
eibach springs on stock shocks
whiteline swaybars set on stiffest front + rear
this combo was PERFECT from a handling perspective, and gave me the look I was going for also. The downside of this was there was absolutely NO dampening, even small potholes and rocks had jarring impact (I wonder if my front shocks were shot?)
Then, I saw a deal on here for preowned tanabe sustec coils that I couldn't resist since I've been curious about the ride on coilovers.
after the coilovers were installed, i noted that there was a huge increase in ride comfort over springs, but some of the mushy/boat/floaty feeling i've had on all my cars had returned. if it wasnt for the notable increase in comfort, i'd switch back to my springs in a heartbeat.
1. ) i'm wondering if anyone has any recommendations which would get me closer to the "riding on rails" feeling I'm looking for?
2.) I hear a lot of talk about swaybar endlinks - how do I know if/when I need them?
thx in advance
Old May 18, 2015 | 08:32 PM
so far i've done:
whiteline coilovers set on stiffest front + rear
thx in advance
If you still have your Eibach springs you might try going w/ Koni Yellow dampers. It does sound like your OEM dampers were getting tired.
Old May 18, 2015 | 08:56 PM
Lego_Maniac's Avatar
Lego_Maniac
[QUOTE=squarehead;3908654]
/QUOTE]
Koni yellows
Old May 18, 2015 | 09:40 PM
HoldmyMouse's Avatar
HoldmyMouse
Sway bars, my friend.
Old May 20, 2015 | 08:11 AM
squarehead's Avatar
squarehead
thank for your responses guys i really appreciate it.
swaybars: I've got whiteline swaybars set on the stiffest setting.
koni yellows Would koni yellows + eibach springs typically provide more precise handling + dampening than coilovers? if so then i'll definitely consider ditching the coils and getting some konis, i have heard good things
endlinks: what about swaybar endlinks? can someone explain the magic behind that? can i visually see if i need new endlinks?
Old May 20, 2015 | 09:15 AM
The Koni Yellows would be an improvement over cheaper coilovers as far as handling & dampening. If you went w/ something like a KWV3 then the coilovers would get the nod, but those are about $2k give or take.
As long as you're happy w/ the Eibach height I think the Konis would be a good plan.
Old May 20, 2015 | 10:14 AM
squarehead's Avatar
squarehead
Crystal clear response, thanks blnewt. I wish there was a way to demo these different setups before committing! I bet being hands-on would be a good upsell/sales pitch for the V3s
Old May 20, 2015 | 01:39 PM
HoldmyMouse
Sorry I meant thicker sway bars. Whiteline is basically same as OEM diameter but with stiffness/travel settings (27mm/24mm). Eibach (32mm/29mm) and Hotchkis (35mm/28.5mm) are significantly thicker and stiffer. Hope this helps.
Old May 20, 2015 | 02:31 PM
TVPostSound's Avatar
TVPostSound
so far i've done:
thx in advance
I'm running Swift springs one Koni Yellows. Comfort is still there, rides like on rails.
Also have Hotchkiss bars.
Had Eibach on stock dampers, I know how you feel.
Old May 20, 2015 | 03:04 PM
TVPostSound
Hotchkis is a hollow bar, makes it lighter, but not the stiffness of a solid 35mm.
misc
29
May 24, 2023 03:57 PM
37
Oct 17, 2020 11:12 AM
2K1 6T8
Oct 6, 2015 07:40 PM
Slapshot1
Sep 27, 2015 08:40 AM
