G37X with eibach pro kit alignment specs..noob help
Got my alignment today after I dropped my X. I was told I will need a front and rear camber kit. Can you guys confirm if I need one, both or any at all?
Camber
Front -1.8 and -2.0
Rear - 2.4 and -2.3
Toe
Front .0 and .0
Rear .05 and .05
Camber
Front -1.8 and -2.0
Rear - 2.4 and -2.3
Toe
Front .0 and .0
Rear .05 and .05
Your rear setup will need attention, camber arms at the minimum & probably a toe kit, luckily they're a lot cheaper than the front, about $150 for the arms and $50 for the toe bolts.
Did you go to a shop that deals w/ lowered vehicles quite a bit? Some chain places like Sears don't seem to take the time or have techs that really work to make things right. If that's the case you might try a different shop (one that may come recommended by someone else on this site) and see if they can get the alignment closer. Eibach drops usually aren't that far off on the camber, at least from most that I've seen.
