Eibach Springs: Camber kit a necessity?
Old Apr 15, 2015 | 10:00 PM
  #31
The hitting of the fender was the earlier SPC kits on slammed drops, A mild Eibach drop w/ current SPC arms will have no such problems.
As far as your tires, what tire brand/model did you have previously?
That .36 toe should have toasted that tire, or at least it should have worn much faster than the others.
If those current alignment settings are accurate than you should expect decent wear, a bit quicker inside tread wear but not crazy.
Those tire mileage warranties are a bit of a sales ploy.
Sure they CAN last 40k miles but for spirited daily driving mileage will probably be less, if you get say 35k miles they just prorate the remaining miles that you're short of your warranty in a new tire purchase.
This warranty makes it seem like you won't be buying tires for a long time and it locks you into another purchase of THEIR tires if you decide to pursue the warranty, a win-win for the tire company
Old Apr 16, 2015 | 01:13 PM
  #32
marcelo19lp's Avatar
marcelo19lp
^^ Thanks for your answer!!! I have the OEM tire sport size in the front 225/45/19 General G Max AS3 currently with H & R 20 mm spacers with the eibach pro kit springs. By putting the SPC camber kit in the front, I still shouldn't touch or slam the fender by bringing the camber to spec?
Old Apr 16, 2015 | 01:17 PM
  #33
marcelo19lp
I had the HankookVentus V12 evo K110 series.
Old Apr 16, 2015 | 02:34 PM
  #34
You'll have no issues
Old Apr 19, 2015 | 05:23 PM
  #35
Roadrash666's Avatar
Roadrash666
Camber kits were not necessary on my car, my fronts are just barely out of spec. I posted a review on the springs along with my alignment specs in the review section.
User 122320
Oct 5, 2015 03:03 PM
Slapshot1
Sep 27, 2015 08:40 AM
jfisher
Sep 9, 2015 04:17 PM
jfisher
Sep 8, 2015 04:16 PM
