Do Vossen 084's + Eibach Springs = Rub?
Old Apr 5, 2009 | 09:49 PM
DCook42's Avatar
DCook42
Just curious if anyone out there with a 37s is running Vossen 084's on Eibach Springs; and if you rub at all or not? Thanks!
Old Apr 5, 2009 | 10:29 PM
ReddieG37's Avatar
ReddieG37
all depends on wheel size, offset, and tire size. if you get the correct sizes, you shouldn't have any rubbing issues.
Old Apr 5, 2009 | 10:54 PM
DCook42's Avatar
DCook42
Well, I ordered the 084's with Vredestein Ultrac Sessanta 20" 245/30 & 285/25 if that helps... gonna try them on before ordering the springs.
Old Apr 5, 2009 | 11:12 PM
myk1013's Avatar
myk1013
What offset and width are the wheels?
And what size tires?
I have 9.5/10.5 inch on mine with Eibachs. with 255/35 and 285/30 Yoko S.Drives
It rubs the fender well liner on big dips and bumps. I can live with it. .
Old Apr 5, 2009 | 11:13 PM
pfizzle's Avatar
pfizzle
^ Same here
Old Apr 5, 2009 | 11:30 PM
DCook42's Avatar
DCook42
I just checked out the vossen website and they are listed as 20x9.0 and 20x10.5. As for the offset, no info. They are supposedly "direct fitment" for the G37S and no spacer is required. Tires listed above.
Old Apr 5, 2009 | 11:48 PM
HamstersG's Avatar
HamstersG
Per PM I have from D2-AUTOSPORT, the offsets at 32 and 37.
Old Apr 6, 2009 | 12:02 AM
jedmonds's Avatar
jedmonds
They don't rub. I have eibach/tanabe combo. And the VS084's do not rub up front, or in the rear, although I have tanabe springs in the rear, I am certain you won;t have issues with the eibachs, since the tanabe's are lower than the eibachs in the rear. I am running 255/35 front 285/30 rear on Yokohama S.drives
Old Apr 26, 2009 | 04:33 PM
TimsG37s's Avatar
TimsG37s
I think you got the wrong info on your springs because the Eibach's are lower than the Tanabe's in rear too. According to Tanabe's website, their NF210 springs for the G37 drop the front 1" and the rear .7" where the Eibach Pro Kit drops the front 1.2" and the rear .8"
kavcheung
Jan 22, 2016 02:40 PM
TheIvoryG
Sep 23, 2015 02:06 AM
Simran Mann
Sep 9, 2015 02:08 AM
uzbekuz
Sep 8, 2015 05:54 PM
