Lowering Springs - Help
Old Apr 26, 2009 | 05:21 PM
amarcusg37's Avatar
amarcusg37
How do Eibach, H&R, and Tein springs differ ? Is one much better then the other ? They are all about the same price so I do not know which to get. Thanks
Old Apr 26, 2009 | 05:34 PM
oOmikeyboy's Avatar
oOmikeyboy
Different spring rates and height of drop.
For example, the eibachs are said to be the right spring rate for our G's, and the drop is minimal at like 1" or so.
The H&R is good also, but its much more significant drop, probably closer to 1.8inches
Then comes the Tein (Htechs or STechs). The Htechs are from the G35 which come with a little more of a bouncy ride, but the drop is perfect (In my opinion) at like around 1.3-1.5 inch. The Stechs are almost as low as the H&R.
It all depends on if you want to go low, or keep it moderate. I would recommend the Eibachs just to keep things simple, that way you won't need a camberkit, and your alignment wont be so bad, etc.
Old Apr 26, 2009 | 06:56 PM
amarcusg37's Avatar
amarcusg37
Thank you . very helpful !
TheIvoryG
Sep 23, 2015 02:06 AM
Simran Mann
Sep 11, 2015 04:42 PM
uzbekuz
Sep 8, 2015 05:54 PM
pnk
Sep 7, 2015 04:31 PM
