Here are my ALIGNMENT specs on fully settled EIBACH springs, no camber kit
I fixed the -4 camber in the back. I had that much negative camber bc of how low the springs dropped the car. I am in spec right now, and my toe is also in spec in the front and the rear. I have -2.0 camber in the front and my tires ARE wearing unevenly even with the toe being in factory spec. It definitely has to be the negative camber. What else would it be?
The previous coupe had tire feathering issues, and from what I understand the geometry of the new coupe's suspension is not much different from that of the previous generation car. Even though tire feathering has not been reported on the G37 (that I know of), maybe if you lower it a bit too much it may have a similar effect as to what used to happen with the previous coupes.
Try to see if you can minimize your front camber to maybe -1.5, and you should be fine. Also, from what I know, the Eibach's don't give you -2.0 in the front, so you must be running a different set of springs/coils.
EDIT: I just went back and re-read your signature. Mistake #1: You put springs on your car that were not made for your car. Springs are built with a specific spring coefficient in mind, depending on the weight and other properties of the car. Mistake #2) you put springs on that drop your car WAY too low, without the necessary alignment adjustment. G35 S-Techs are not really a wise choice.
^sw33t, good to kno blackjack. I'm not too worried since im at -2.0 in the rear, and have some + toe front and rear to try to even it out.
I'll post back after like 7500 miles as to my tire wear.
hope this helps...
