wheels and 0-60 times
Old Apr 11, 2008 | 03:03 PM
COMark's Avatar
COMark
Couple questions, if anyone can help that would be great.
I've been looking for 0-60 times for the various G models and can't find em. At this point I'm more interested in the official Infiniti numbers for the Journey w/Auto, but will take what I can get.
Other question, I think I read that the Journey Sport package includes bigger brakes. I'm not a fan of 19in wheels (wear too fast, cost too much to replace, rougher ride IMHO) Will 18's fit on a G37S?
Old Apr 11, 2008 | 03:13 PM
joeposter's Avatar
joeposter
Not all of them. They have to be cut for big brakes.
Old Apr 11, 2008 | 03:26 PM
PSYH's Avatar
PSYH
Post Whore
Motor Trend estimated 0-60 in 5.2 and Road & Track says 5.5, both for the 6MT.
Old Apr 11, 2008 | 04:20 PM
chris_0260's Avatar
chris_0260
The wheels wear too fast? Now sure I follow...
Old Apr 11, 2008 | 05:53 PM
COMark's Avatar
COMark
I figured someone would comment on that. 19" tires wear faster and cost more to replace than 18's.
Old Apr 11, 2008 | 08:55 PM
Achilles's Avatar
Achilles
Why would 19's wear too fast as opposed to the 18's?
Old Apr 12, 2008 | 04:37 AM
prutkows's Avatar
prutkows
http://www.performancecarnews.com/Fa...cess=ShowTable
claims 4.9 0-60 in G37s.
lies, unfortunately.
There is no significant difference in tire wear between 19" and 18" If anything you'll have to replace your 19"s a few weeks sooner than your 18"s.. not a big deal.
Old Apr 12, 2008 | 07:27 PM
TerribleONE453's Avatar
TerribleONE453
i dont think the wear will be different... more expensive? yes
Old Apr 13, 2008 | 03:18 AM
UNV-IT46's Avatar
UNV-IT46
If your talking about the sport brakes. yes they are going to wear faster. the pad is softer then the standard brakes. if your talking about the wheels. then the size is not going to matter. if you have the oem tire bridgestone reo50's in either 18 or 19 they are going to wear the same.
Old Apr 13, 2008 | 11:33 AM
COMark's Avatar
COMark
Every tire guy I've ever talked to has told me the lower the tire profile the faster they'll wear. Something to do with heat buildup and having less sidewall to help the heat dissipate. I've never had first hand experience though.
Old Apr 13, 2008 | 02:05 PM
UNV-IT46's Avatar
UNV-IT46
i dont agree at all. on my S2000 the oem side wall was 45's and when i switchted to the same tire but in 18"s with a 35 side wall they wore the exact same
Old Apr 13, 2008 | 05:53 PM
TerribleONE453
yupp... ^ i dont think the heat has anything to do with it... maybe a 20 mile difference?
Old Apr 13, 2008 | 06:45 PM
UNV-IT46's Avatar
UNV-IT46
the only time you will see a significant change in wear is when you add a wider tire because you are changing the contact patch on the ground. so you may see un even or sparatic wear throughout the tire if you dont compensate the air pressure to balance everything off. even then it will still wear odd..
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
GFTW
Nov 11, 2015 02:56 PM
james6980
Oct 9, 2015 01:28 PM
joeposter
Sep 8, 2015 04:36 PM
Digilog
Aug 17, 2015 03:54 PM
