G37xS - Suspension Questions
Old Mar 4, 2019 | 06:36 AM
Redgoyabean's Avatar
Redgoyabean
Ok guys I've seen many on the road with the badge on that reads (g37xs) on a sedan. Now my simple question ISSS, if the g37xs sedan is an actual trim option (which means it should have sport suspension on a awd sedan which I guessing would be koni dampers just like the sport sedan) then should they be interchangeable for the g37x sedan that I have. I want swift springs but don't want them with stock dampers, so guys plz let me know if this is possible, I'm going to call a dealership today to find out if the trim is officially n if so can the simply be swapped. Thank in advance.
Old Mar 4, 2019 | 07:23 AM
llebcire's Avatar
llebcire
Quick Google search for brochures:
Auto-Brochures.com|Infiniti Car & Truck PDF Sales Brochure/Catalog/Flyer/Info EX FX G Convertible G Coupe G Sedan JX M Q40 Q45 Q50 Q60 Q70 Q70L QX30 QX50 QX56 QX60 QX70 QX80
2013 G37 Specifically:
http://www.auto-brochures.com/makes/...sheet_2012.pdf
Snip from brochure:
-Eric
Old Mar 4, 2019 | 07:34 AM
The xS Sedan didn't come with a sport suspension. Dampers and RSB are the same as the non-Sport.
The only suspension differences between the Sedans was a thicker RSB in the RWD car (irrespective of the Sport Package), a lower engine cradle brace in the AWD car (also irrespective of the Sport Package), and sport-tuned Tokico dampers in the RWD Sedan with the Sport Package (which included the 6MT, naturally.)
That's it.
Old Mar 4, 2019 | 08:05 AM
Redgoyabean
Damn man that really sucks, but thanks guys this is why I ask to be informed. It sucks though I really want swift springs for the perfect drip they provide but I hear when paired with stock dampers you get a real nasty ride.smh.
Old Mar 4, 2019 | 09:05 AM
Corprin's Avatar
Corprin
Nasty ride is subjective. They are progressive springs, so it’s hard to tune around the variable spring rates with any shock.
Old Mar 4, 2019 | 09:42 AM
Redgoyabean
your right some ppl say the g37s sedan rides rough, I've owned Altima se-r on lowering springs n it was rough but not bouncy which is what I've read most with the swift n stock dampers, I can deal with rough but don't want to be bouncing all over the place n for some reason no one can chime in on that combo, g37x sedan with stock dampers n swift springs.
Old Mar 4, 2019 | 08:25 PM
Invaderzim's Avatar
Invaderzim
I have an awd sport coupe with swift springs. Not a harsh ride at all. Not bouncy either. The ONLY time I feel a difference from stock is when hitting a real bad pothole or big sudden drop. Actually I think it rides much better than stock. Not nearly as much roll when cornering and the car feels more responsive. No regrets here. My 2 cents.
Old Mar 4, 2019 | 09:55 PM
Redgoyabean
Do you know if the spring rate between the 2 are the same??
Old Mar 5, 2019 | 01:37 PM
Said Amir's Avatar
Said Amir
I have KYB shocks and struts with swift and the ride is really good I love it so far. I have a G37xS coupe. Btw the rear shocks are interchangeable with the regular G37 except the fronts
Old Mar 5, 2019 | 01:53 PM
Redgoyabean
ok ima just go with kyb n swift, I'm not expecting a like stock when it comes to comfort just hope she's not bouncy n thanks for all the feed back, much appreciated.
Old Mar 5, 2019 | 07:33 PM
Said Amir's Avatar
Said Amir
To be honest it legit rides like stock and actually a bit better on normal roads. But when you hit bumps you do feel it but it’s nothing dramatic. This is just my opinion and also my first car that I have ever lowered. Another thing make sure to get rear camber arms and toe bolts. If anything I would recommend getting front camber arms also but that just depends on if you’re okay with driving on -2 degree camber up front.
deep0542
Feb 18, 2022 09:31 AM
vq’ed
Jul 14, 2019 03:37 AM
Jawad Haq
Buying & Leasing
Feb 20, 2019 04:21 PM
skrolz
Feb 14, 2019 10:31 AM
Billnard
Jan 12, 2019 02:03 PM
