2010 G37 Convertible Rear Shock Replacement
Old Nov 6, 2018 | 04:06 PM
lusecannon's Avatar
lusecannon
Hi,
I have searched high and low, talked to my Infiniti dealer who had no clue and actually referred me to a speed shop who also had no idea, so I thought maybe you guys could help. I am trying to find replacement shocks for the rear on my 2010 Convertible. The issue is the lower part of the shock and how it connects, on the convertible it is to the front side of the control arm whereas the coupe is on the rear and there is a different bracket.
The part number listed on the shock is 56210K, and I cannot for the life of me find a replacement. I ordered a pair that were supposed to be for the rear, but they were for the coupe and wouldn't fit. If you look at Infiniti parts deal online, and search for part 56210K it pulls up and the main diagram clearly shows the right part (lower connection) but the recommended replacement part (E6210 JJ2A) is for the coupe as it has the coupe bracket for mounting: Infinit parts deal
I know there are coil over kits available but I really would just prefer to keep the factory set up (this is not a daily driven car and not worth the expense).
Any ideas?
Old Nov 12, 2018 | 07:53 PM
Seems to be slim pickings for the rear set, found these~not sure if you can but you might have to reuse that lower mount if it's removable???
https://www.ebay.com/itm/SENSEN-1085...-/392081171087
G37xS-Life
Oct 21, 2018 12:57 AM
Inflictor
Dec 21, 2017 07:58 PM
speedboost
Dec 20, 2016 01:34 PM
bikezilla
Jul 17, 2016 01:18 AM
jsampsell
Nov 14, 2015 06:14 PM
