Pulls right on hard braking
Old Apr 18, 2018 | 06:38 PM
G37xS-Life's Avatar
G37xS-Life
Anyone have any ideas why my G37xS coupe pulls to the right when I brake hard at higher speed?
Alignment recently done and runs straight when not braking. I have OEM rotors and using Nismo brake pads. Winter tire are in great condition and new from this winter.
Also, I noticed my brake fluid in the reservoir dropped by 1 mm recently. Is this a sign of potential leak in the brake lines somwhere?
Thank you all in advance.
Old Apr 18, 2018 | 07:02 PM
jpowersjr2's Avatar
jpowersjr2
Sounds like something wrong with the piston inside the caliper. How old are the brakes? If you're pads are worn the brake fluid technically should drop some (correct me if I'm wrong). I just did pads/rotors all the way around a couple weeks ago on mine.
Old Apr 18, 2018 | 07:14 PM
G37xS-Life's Avatar
G37xS-Life
The Nismo brake pads and brake fluid were changed 5,751 miles ago.
The Akebono brake system is 6 years old (bought the car brand new).
How do I know if it is a brake caliper issue? If so, driver side or passenger side?
Old Apr 18, 2018 | 07:33 PM
Surfnazi's Avatar
Surfnazi
Because one side is gripping less than the other probable need to rebuild the caliper
Old Apr 18, 2018 | 07:35 PM
G37xS-Life's Avatar
G37xS-Life
I am assuming if a rebuild is needed, then its the driver side since the car pulls right?
Old Apr 19, 2018 | 05:28 PM
Surfnazi's Avatar
Surfnazi
Possibly but it's also best to check all of it
Old Apr 19, 2018 | 09:09 PM
NealP's Avatar
NealP
I had a similar issue and it ended up being the caliper pin wasn’t moving as it should. I removed it, cleaned it, and supplied new caliper pin grease and boot. Good as new. Not so much for the rotor though as it had been gouged.
Old Apr 22, 2018 | 12:07 AM
G37xS-Life's Avatar
G37xS-Life
Thanks all. I will have all the calipers and pins inspected. Hopefully, its nothing serious.
Scottfreidel
25
Jun 19, 2023 07:22 PM
Joe'sG37
Apr 19, 2018 11:37 AM
krazzyborri
Apr 17, 2018 02:29 PM
dareez
Mar 31, 2018 01:36 AM
