Which of these rotors will work?
Old Apr 10, 2018 | 08:36 PM
HotSawce's Avatar
HotSawce
So upon going to rockauto.com to find some rotors for my 2013 G37 sport coupe, I was bombarded with probably close to 100 different options of rotors for our vehicle.
https://www.rockauto.com/en/catalog/...hub,rotor,1896
I'm getting very confused as to which will fit my specific vehicle and if you click the link above, you may understand why. Furthermore I don't know which I should actually buy from a quality perspective. What's the lowest I should be spending per rotor? I'm definitely on a budget and don't really care for very expensive rotors. (or should I?)
I found these ones for example Which are drilled & slotted and $95 for the pair.
Whereas after doing a bit of research I saw the members recomended these, the centric premiums which are neither slotted & drilled and about $90 each.. I'm confused as to why the drilled & slotted ones are close to the same price as just 1 of the centric premiums.
All in all, I was hoping you guys could point me in the right direction.
Thanks!
Old Apr 10, 2018 | 08:48 PM
saywat?'s Avatar
saywat?
i usually go to autoanything.com and spec out the rotors there from centric. then based off those findings you will know what size u need and a price. then go from there. i dont need high performance ive been happy with centrics either blanks or slotted
Old Apr 10, 2018 | 10:54 PM
Centric Premiums are about the best bang for the buck, and if you want ones that are already heat cycled get the cryo treated Centrics, just be sure to select the 355mm front 350mm rear sets as the descriptions on rockauto can get confusing.
Don't forget to google "rockauto discount codes" for the current 5% discount that you enter in the "how did you hear about us" box at checkout
ANMVQ
24
Jul 3, 2018 01:20 PM
NCG37sC
Apr 17, 2018 11:14 AM
G37sPhoton
Mar 8, 2018 09:38 AM
vq.chris
Mar 6, 2018 07:54 PM
