Akebono conversion ???s
Old May 4, 2016 | 01:45 PM
azndragon2222's Avatar
azndragon2222
i'm not car tech guy so bear with me if this has been asked before. i want to put Akebono big brakes onto my '12 G37xS (AT). my question is, if i just get the calipers (and clips?), is installation just plug and play? if not, what other components would i need for it to work?
Old May 4, 2016 | 01:46 PM
Ricio1991's Avatar
Ricio1991
Banjo bolts and yes it will be plug and play and of course you will need the bigger rotors too and brake pads
Old May 4, 2016 | 01:49 PM
slartibartfast's Avatar
slartibartfast
Sure seems like the Akebono sticky thread at the top of this forum has all the info you need.
Old May 4, 2016 | 01:54 PM
azndragon2222
im assuming id need new banjo bolt for each one (4 total)?
VenomGT9's Avatar
VenomGT9
And I have the calipers you need
Old May 4, 2016 | 02:02 PM
azndragon2222
pm'ing you
Old May 8, 2016 | 05:24 PM
VIVID's Avatar
VIVID
Pyroclastic Flow
I've done the BBK conversion.
Should I consider a master cylinder upgrade as well? There is some indication elsewhere that this might be useful.
Is the MC different on the S models vs. non-S models?
To be sure, the brakes do feel great. No fade, linear response, good pedal feedback. So I'm wondering.
Thanks,
Sean
Old May 13, 2016 | 02:09 PM
azndragon2222
ahhhh yaaaassssss
Old May 13, 2016 | 02:54 PM
G10's Avatar
G10
1. Yes, for the most part it's plug and play with some modification needed. You'd need to have to shave off the black plate( dust shield) of your current rotors to fit the bigger caliper. It is a DIY but if you're not a handyman then you should get it done by our local machanic.
Here is a well written instructions for the upgrade
2. Read up on a post by blnewt [URL="https://www.myg37.com/forums/brakes-and-suspension/258336-new-akebono-bbk-on-the-cheap.html"]here about buying calipers/rotors/pad for a discounted price.
3. Banjo bolts - You need longer Banjo bolts but if you also upgrade your brake lines these bolts will come with it.
4. One thing to note, If you choose this route then you should know that you can no longer use your current spare tires. You'd need to buy a spare tire that will for a sports sedan for fulfilment. ( Again this is optional)
Old May 13, 2016 | 03:00 PM
G37xhibeet's Avatar
G37xhibeet
Post above you; they already did it
Old May 13, 2016 | 03:03 PM
G10's Avatar
G10
ahhhhh, ya just noticed it...
masterdukill
Aug 26, 2016 02:44 AM
the93owner
May 21, 2016 10:19 AM
kevinmward
May 10, 2016 05:25 PM
Beachbodyg37
Apr 9, 2016 01:17 PM
TVPostSound
Apr 7, 2016 07:21 PM
