Tein Basis Coilovers? Yes, no?
Old Jul 22, 2017 | 07:31 PM
  #166
Yep, quality 18s in that size will work well. Might also look at just slightly stiffer front springs w/ those shocks, Tein or Swift should be able to supply them.
Old Jul 22, 2017 | 09:39 PM
  #167
4DRZ's Avatar
4DRZ
Originally Posted by future62
my Nexen 5000 225/245s gave up the ghost with any kind of aggression. They were downright scary in the wet. Now, same exact tires, I find it hard to break traction. And when it does break it's a lot more progressive and controllable.
If you want more grip, focus more on the type/treadwear/brand of tire you get than the size. Many times more improvements to be made with stickier tires than wider tires.
Old Jul 22, 2017 | 10:22 PM
  #168
future62's Avatar
future62
Yea, I really do think quality 245s all around would be great. Plus that would keep tire roar down. I'm just not sure if I want to get 10Ks in back or get a stiffer RSB. It might amount to the same thing. With the relative motion ratios that 10K is really like a 5K compared to the 9K up front, so it's no surprise it feels a bit soft.
Old Aug 4, 2017 | 07:40 PM
  #169
future62's Avatar
future62
The longer I drive these, the softer they feel. Not sure that is good or bad, though I am dying to know what the Flex Zs feel like now, especially broken in. I'm thinking about going with the +2K spring upgrade all around.
Old Aug 5, 2017 | 08:24 PM
  #170
Huaniitoo's Avatar
Huaniitoo
I have about 4months with mine and they feel amazing.. 2k spring upgrade? Softer springs is it. Or what do you mean by that
Old Aug 5, 2017 | 08:48 PM
  #171
future62's Avatar
future62
4 months on your Flex Zs? And I would do 2K harder springs on my Basics.... 11/10K F/R. For all that hassle though I might as well get the Flex Zs. How are the roads where you live?
Old Sep 13, 2017 | 06:00 PM
  #172
sr20dehauler's Avatar
sr20dehauler
Would anyone with the Tein Basic coilovers not recommend installing these on a car used for carpooling with three older women (if that even makes a difference).
Old Sep 13, 2017 | 09:12 PM
  #173
saywat?'s Avatar
saywat?
are they fat? bc
Old Sep 14, 2017 | 09:33 AM
  #174
future62's Avatar
future62
How are the roads by you? I probably would not honestly.
Old Sep 14, 2017 | 11:37 AM
  #175
Lego_Maniac's Avatar
Lego_Maniac
Originally Posted by saywat?
are they fat? bc
Sadly, +1
While I very, very rarely scrape, I had a $500 Costco run last weekend and couldn't even get a finger between tire/fender. I scraped on a speed bump
I'm not on Tein, but I think passenger weight is going to make a difference.
Old Sep 14, 2017 | 02:49 PM
  #176
future62's Avatar
future62
FWIW, I used to scrape with my bone stock 350Z. Some speed bumps are just killer.
Old Sep 14, 2017 | 06:46 PM
  #177
Lego_Maniac
I've never seen speed bumps so common as in NC.
Old Sep 14, 2017 | 07:03 PM
  #178
4DRZ's Avatar
4DRZ
Probably not unless your roads are pretty smooth. Especially not if you have roads that are rather bouncy- for obvious reasons.
Old Sep 19, 2017 | 12:13 AM
  #179
sr20dehauler
Thanks for the responses. I guess I'll stick with the stock suspension or possibly try the front Tanabe springs with the 1/4" spacer and cutting the rear spring perches 1/2". I'm only looking for a mild drop, but it will need to retain the comfort of the stock suspension.
Old Dec 23, 2017 | 10:49 PM
  #180
staskz's Avatar
staskz
just did the fronts! super easy, gonna do rears tomorrow. So far im excited to drive this thing when done! it definitely looks amazing lowered, im at about 26" in the front, might have to raise it up a little once it settles cause i imagine it will be lower. or maybe ill go with that
