Brakes & Suspension Reviews on brakes & suspension for G vehicles.
Review Tein Basis coilovers on '13 G37S sedan 6spd
Old Dec 16, 2017 | 12:10 AM
  #106
Kpmikey808's Avatar
Kpmikey808
Originally Posted by 4DRZ
That would make the ride even more stiff. I think we would need better dampening. Then again, it is pretty hard to make any coilover ride well on the street.
How much do konis run? I think they would make ride nonbouncy
Old Dec 16, 2017 | 01:40 PM
  #107
future62's Avatar
future62
I looked into substituting Konis in. It's definitely doable. I made a thread here:
https://www.myg37.com/forums/brakes-...-location.html
All we would need is the locking circlip for the front Koni shock and a 2.5" ID spring sleeve + collar. Would probably cost ~$1100; another $200 if you wanted to change the spring rates. Basis Zs are working for me now but if they ever blow I'm going this route.
Konis will work much better. They are adjustable and their rates are perfect... strong body control and supple bump absorption. They've been great on every car I've had them on.
Old Dec 16, 2017 | 04:41 PM
  #108
4DRZ's Avatar
4DRZ
This is using the Koni yellow shocks for the 370Z like they have listed on tirerack? What springs would you use?
I can vouch for Koni's ride. I had some Koni inserts on a WRX and they were great. Rode well on the street and you could tighten them up for track days. I did blow one out on a track that had a dip in it and they sent me a new one. The lifetime warranty is always a bonus.
Old Dec 17, 2017 | 12:08 AM
  #109
future62's Avatar
future62
Yes they are those shocks. I'd probably get 600/500lb springs. Up front I think they are 8x2.5", out back they are 9.5x5.5".
Old Jan 6, 2018 | 01:32 PM
  #110
Kpmikey808's Avatar
Kpmikey808
Pic of where control arm hitting
top nut part of control arm hits right here when I’m going to fast & heavy load in car- when it knocks u can hear it
Old Jan 6, 2018 | 03:52 PM
  #111
4DRZ's Avatar
4DRZ
Has anyone tried this yet? I am starting to consider this for the front as I hope it would make the car smoother on the newer wavy roads. Where do you go for the circlip, spring sleeve, and collar? Would we need any additional parts for the rear suspension?
Old Jan 6, 2018 | 05:53 PM
  #112
future62's Avatar
future62
I can't post the link now, but you will need a Koni circlip, sleeve kit and I believe a 2.25 or 2.5 ID spring of your choosing. I'm personally still leaning towards the Flex Zs as they are cheaper and close to the specs I want.
Old Jan 7, 2018 | 06:33 PM
  #113
4DRZ's Avatar
4DRZ
Yes, I have that info. you provided earlier quoted in my post. I was just wondering where to obtain those parts.
Old Jan 9, 2018 | 07:14 PM
  #114
future62's Avatar
future62
Ah-
Clip
Sleeve kit
Old Jan 11, 2018 | 02:09 PM
  #115
4DRZ's Avatar
4DRZ
Well, that doesn't look so bad. Does anyone have Koni's on their sedan who can comment on the ride?
Old Jan 11, 2018 | 02:57 PM
  #116
Lego_Maniac's Avatar
Lego_Maniac
Full soft is stiffer than stock and a good starting point, I've tightened them a full turn and it was too stiff. No bouncing and they're great an handling dips and elevation changes. Obviously pot holes and stuff like that hit harder.
Downside: rears are tough to adjust on the car.
The lower spring perch can be mounted upside down, which years ago caused people to believe they raised the ride height, but were ultimately installed incorrectly.
Old Jan 11, 2018 | 04:50 PM
  #117
4DRZ's Avatar
4DRZ
That's good to hear. The only thing I am not in love with on the Tein Basis is how bouncy they are on newer roads that are kind of wavy. They actually handle bumps ok, but they do bounce a bit. It would also be nice to be able to adjust them differently for street/track.
What springs do you run Lego?
Old Jan 11, 2018 | 05:07 PM
  #118
saywat?'s Avatar
saywat?
^then u dont get the basis aka basic.
Old Jan 11, 2018 | 05:22 PM
  #119
4DRZ's Avatar
4DRZ
Your screen name is my response to your post. I must be reading it wrong. What are you talking about?
Old Jan 11, 2018 | 05:25 PM
  #120
saywat?'s Avatar
saywat?
u said u wish the basis u can adjust differently for street/track. now read my post again
