Brakes & Suspension Reviews on brakes & suspension for G vehicles.
Review Tein Basis coilovers on '13 G37S sedan 6spd
Old 11-12-2017, 09:17 AM
  #76
future62
future62's Avatar
Originally Posted by Marcel4t
How low a drop do you have that it's bottoming out the FUCA?
It's a regular drop (~26" FTG) and it was fine with the stock FUCA. Only got the banging once I put the SPC arms on.
Kpmikey808 (11-29-2017)
Old 11-12-2017, 10:04 AM
  #77
Crazyirish
Crazyirish's Avatar
Common issue with that style camber arm on many different platforms.
Old 11-14-2017, 04:41 PM
  #78
Entcee
Entcee's Avatar
I had to raise mine to 26.75 because the SPC arms were hitting the fender going over small-ish bumps.
Old 11-14-2017, 05:53 PM
  #79
future62
future62's Avatar
With the Teins? Damn that is high, that's damn near stock
Camber wasn't that bad with the stock arms, I just need to find the time to go back to stock
Old 11-14-2017, 05:58 PM
  #80
saywat?
saywat?'s Avatar
someone should try the chinese ones on ebay. they dont have the caster adjusment. that seems to be the issue with the spcs. its too high
Old 11-14-2017, 06:09 PM
  #81
Crazyirish
Crazyirish's Avatar
Its usually the shoulders around the ball joint where you loosen the bolts for adjustment. This area is a good bit longer/wider than the stock arm. Honda guys frequently have this issue. Its why most of the nicer (amd even SPC’s own higher end version) control arms adjust along the arms themselves rather than at the ball joint.
Old 11-14-2017, 06:31 PM
  #82
saywat?
saywat?'s Avatar
^that shoulder issue is resolved using g35 arms. i believe that was spcs solution from what i read here. but owners were still hitting and it was the caster adjustment part . idk im just going what i remember i could be wrong
Old 11-14-2017, 06:39 PM
  #83
Entcee
Entcee's Avatar
Yes, with the Teins... But it's far from stock height. (Friends vert wheels I had on for a week or so).
Old 11-14-2017, 06:42 PM
  #84
saywat?
saywat?'s Avatar
^looks good
Old 11-19-2017, 04:37 PM
  #85
future62
future62's Avatar
Just figured something out. These springs sag a little over time. Car is a good 1/2" lower than when I settled on my height. In the front, no problem, plenty of room. In the back, no bueno, I'm tucking tire at what I remember being the top setting. I just ordered a spring spacer but I will see if I have adjustment room over the Thanksgiving break.
Old 11-19-2017, 11:39 PM
  #86
saywat?
saywat?'s Avatar
That's weird mine hasn't sagged. Ur Maxed out that s why u can raise it more?
Old 11-20-2017, 09:05 AM
  #87
future62
future62's Avatar
I will try and check how much room I have tomorrow night. But IIRC I was maxxed out on rear height. Maybe I didn't tighten the collars enough?
Old 12-13-2017, 12:34 AM
  #88
Kpmikey808
Kpmikey808's Avatar
did u check- did it sag
my teins settled about 1/4 inch i believe
ill take different measurements FTG cause of uneven surfaces
i was 26.5 and after i measured was 26.25
Old 12-13-2017, 10:26 AM
  #89
Marcel4t
Marcel4t's Avatar
I need to raise my front end up. I was at 26 1/4 and they settled to 25 3/4...way to low, hitting some vertain bumps, well actually dips, UCA hitting top of wheel well I think. But, the ride is awesome with these CO and Sways, just what I was looking for. Almost like stock, but so much more planted, and barely any roll. Im very happy!
Old 12-13-2017, 11:15 AM
  #90
Kpmikey808
Kpmikey808's Avatar
Teins settled lower
I see on average twins settled about 1/2 inch lower- my front right fuca will hit on bad bumps- can anybody chime in on how to fix that problem?
Marcel did u have mechanic install yours
Post some pics marcel so I can see please
Quick Reply: Review Tein Basis coilovers on '13 G37S sedan 6spd
