Eibach Spring Install on G37x
Old Aug 25, 2015 | 06:23 PM
Takran's Avatar
Takran
Some Guy
Rears are incredibly simple, fronts are a huge pain on the X. When I installed my coils, I followed this:
https://www.myg37.com/forums/d-i-y-i...l-on-an-x.html
and this has good instructions for unbolting the A-arm (step 6 of the front coil install in the above link, you don't need to remove the A-arm if you're not installing a camber kit, just unbolt it so the assembly drops):
https://www.myg37.com/forums/d-i-y-i...er-adjust.html
Those two saved my life, I was stuck on my front install until I found those.
Old Aug 25, 2015 | 06:34 PM
jfisher's Avatar
jfisher
Looks good! I am receiving similar quotes here locally and it's just not worth it to me to pay someone that much to do such a simple install.
Old Feb 5, 2016 | 10:57 AM
GeeX's Avatar
GeeX
I have a 2012 G37X that I dropped on Eibach's - these are designed for the RWD model only and my rear suspension dropped way lower than the 1.4" advertised on eibach.com. The rear suspension sags more than the front and looks terrible. Also as the springs settle it gets worse over time.
I'm switching out my rear suspension with Swift's which are designed for the X model - the advertised drop is 0.8 - 1" so that should make a difference.
Old May 12, 2016 | 10:50 AM
KG_Broheen's Avatar
KG_Broheen
I just dropped my 2011 x sedan on Eibach's (6390.14) and the rear springs are physically shorter than the stock rear springs, I knew this would cause an unintended increase in rear-drop, but I guess this is the result of purchasing springs designed and tested for another model. I can live with this.
What I CAN NOT live with is the horrible clunking sound coming from the front end. I've checked the tie rod end-links and sway bar end-links. I've tightened the a-arms in the loaded position, and have done whatever else I can think of to check for the source of the problem. Has anyone else had a similar issue?
Here's everything I installed:
- Eibach Pro-Kit (6390.14)
- SPC Camber Kit (f/r)
- 20mm spacers (f)
- 25mm spacers (r)
Any advise or solutions would be awesome. The springs are not binding, and they come with plastic shields between each coil to prevent metal-on-metal contact during compression. Could the shock's piston be hitting the bump stop in the strut?
Old Jan 4, 2021 | 11:32 PM
Kabriola's Avatar
Kabriola
Originally Posted by vamarris
All done and very happy with the look so far. I will know more once they have an opportunity to settle a bit.
If anyone else has questions or needs help installing springs on AWD I am happy to try and help.
Hey Ik this post is old but was wondering the part number for the springs?
G's
Nov 5, 2023 12:01 PM
tdoug
May 24, 2017 08:23 AM
cy7878
Jan 2, 2013 03:38 PM
Sarah Brown
Dec 26, 2012 10:12 PM
