Droopy Bum Fix for the G Sedan - Version 2.0
Old Jan 10, 2021 | 09:01 PM
  #106
Impressive work. I laughing to myself, familiar with the obsession that's been motivating you.
Old Jan 10, 2021 | 09:07 PM
  #107
backman_66's Avatar
backman_66
It's almost gotten me killed by my wife for spending so much time working on it! I'm just relieved I'm finally in a satisfied place with it now so I can get it aligned. Part of the reason I didn't want those rears too low is to make sure they can get the camber close enough to spec. It'll save me money in the long run to get it right, now.
Old Jan 10, 2021 | 09:16 PM
  #108
backman_66's Avatar
backman_66
Old Jan 10, 2021 | 10:01 PM
  #109
iCrap's Avatar
iCrap
Wonder if anyone else is still running the coil sleeves. Mine are still in, looks like I made that post on 06-26-2017. Zero sag since then.
Old Jan 1, 2025 | 06:17 PM
  #110
jezdfax's Avatar
jezdfax
Rear Springs
Hi guys. Just need a little advice from you young gear heads out there. Im 66 and have a 2008 G37 Journey coupe I bought in 2018. Clean with 95,000 miles. I’m getting rear sag with more on drivers side. I’m sure it has the stock springs/shocks. What would be the better way to raise the rear to stock height with the best results. I know there are many different options available. Thanks.
Old Jan 2, 2025 | 10:17 AM
  #111
Car Analogy's Avatar
Car Analogy
Something is wrong, and needs to be fixed. This isn't a situation where you need to change design by inventing parts, as people did in this thread to alter the design of parts with different design than stock, but the non stock design wasn't what they wanted. So they further altered the non stock design.
If you're all stock and now suddenly sagging, something broke and needs to be fixed.
Old Jan 2, 2025 | 10:22 AM
  #112
Yes, that's exactly what I did when creating this thread 10 years ago. Not my proudest moment.
jezdfax, if one rear corner is noticeably lower than the other, then something is broken, just like Car Analogy said. Get it up on a lift.
Old Jan 2, 2025 | 12:34 PM
  #113
rotarymike's Avatar
rotarymike
Moderator in Moderation
If it's just a little different, likely a rear shock has lost its gas charge. Easy to replace. Would not recommend adjustables or coilovers unless you can articulate a specific need for them.
If it's more, probably a bushing. Get her up on a lift and start wiggling/prying on stuff.
OEM springs (car springs in general) RARELY actually go bad, other than even sag over long, long periods of time. But rare ain't never.
Dembflyr
Jan 1, 2026 11:20 PM
KidJai06
Car Care & Detailing
14
Jul 6, 2024 07:15 AM
FlashGuy
Aug 28, 2021 10:02 PM
May 26, 2015 09:49 PM
edge540
17
Oct 28, 2010 08:48 PM
