G37 Rear Brake/Rotor Replacement
Old Jun 4, 2015 | 10:45 AM
securityguy's Avatar
securityguy
Planning on replacing my rear brake pads and rotors this weekend. Does anyone have a nice link or detailed instructions on how to get the rear caliper off of the vehicle to access the pads and the rotor? My car has the non-sport brakes. Thank you!
Old Jun 4, 2015 | 11:02 AM
BrianJC's Avatar
BrianJC
Maybe this helps?
Install front and rear break pads
Old Jun 4, 2015 | 11:19 AM
securityguy
Thanks Brian but this does not show me how to get the caliper totally off so that I can replace the rotors. Is there another set of instructions on the forum that explain the removal of the entire caliper?
Old Jun 4, 2015 | 01:30 PM
I have the sport brakes, but the process should be the same. There are only 2 bolts holding on the caliper. They're pretty obvious on the sport brakes, the only 2 bolts attaching the bracket part of the caliper. Remove these and support the caliper by hanging it with a wire or string so that the brake lines aren't pulled. There is no need to remove the brake line from the caliper or to take it apart to replace the rotors or pads.
Chris Olson
Dec 29, 2025 07:59 PM
GW330
Feb 2, 2024 05:41 PM
e92ry
Dec 31, 2015 08:02 PM
jayrdong
Oct 25, 2015 10:00 PM
