Scrapped slotted rotor question
Old May 18, 2015 | 09:57 AM
mbar's Avatar
mbar
Drive 2013 G37xS coupe (big brakes) with slotted rotors.
On my recent track day it looks like my front left race pad started crumbling a little and a piece grooved the rotor (one circular groove around).
I replaced the pads (still need to bed in the new pads). I do feel a little brake judder under hard braking.
1. should I replace the rotor?
2. can I buy a different brand set of slotted rotors for the fronts from those I have in the back?
3. very annoying that this rotor brand only sell them in pairs
Thanks for your help!!
Old May 18, 2015 | 11:43 AM
If the groove isn't too deep you might get it machined, just have to find a shop willing to do it
Can Drilled/Slotted rotors be turned? - Corvette Forum
If you indeed need a new rotor have you contacted the vendor or manufacturer just in case they could sell just the single rotor?
G/L
Old Jun 4, 2015 | 04:53 PM
mpegripper's Avatar
mpegripper
if you've grooved the rotor, it means it probably also got a lot hotter near there which would mean the metal is somewhat compromised. if its a brand new rotor, its worth turning the rotor. if its got a lot of miles on it already, just replace it. remember the rotors only wear 2mm or so before needing to be replaced.
OneSickBlackG
Jan 6, 2016 08:49 AM
Feffman
SouthEast
Oct 11, 2015 08:55 AM
Feffman
Upcoming Events
Oct 8, 2015 08:16 AM
photocat
Sep 3, 2015 01:46 PM
