Lowering an AWD
Old Apr 30, 2015 | 10:41 PM
Dillybar12's Avatar
Dillybar12
Lowering an AWD
Hello all,
I currently own a 2010 G37x non sport.
I am more than likely looking to lower my car, however, I do not want to void any warranty that I have with my dealership.
Also, I have read some forms that said it is bad for the AWD system. Is this true?
Thanks
Old May 1, 2015 | 12:30 AM
Originally Posted by Dillybar12
Hello all,
Thanks
It won't void the warranty but if a suspension component were to go bad it could get complicated. Won't cause any AWD issues except having the transfer case closer to the ground which may be a problem if you drop too low.
A mild Eibach, Tanabe, or Swift spring drop should be pretty easy to live with on a daily driver.
Old May 3, 2015 | 01:09 PM
Dillybar12's Avatar
Dillybar12
Overall quality, eb. The best way to go?
Old May 3, 2015 | 01:34 PM
Dillybar12's Avatar
Dillybar12
If a quick link could be provided that would be appreciated!
Old May 3, 2015 | 06:00 PM
This white X coupe on Eibach springs
https://www.myg37.com/forums/brakes-...ml#post2864076
Tanabe springs on the X coupe
Tanabe USA R&D Blog | Infiniti G37 Coupe
Swifts are still in development for the X Coupe unfortunately
https://www.myg37.com/forums/g37-cou...-act-fast.html
Old May 3, 2015 | 10:50 PM
Dillybar12's Avatar
Dillybar12
Thanks for the links. I spoke to you before about my wheels. I am looking to lower now, which means, I will be looking for 20 inch wheels now...
Could you give me the best lowering kit to run on an AWD with 20s in the summer, yet the standard 18's in the winter... Thanks man. Youre the biggest help
Old May 3, 2015 | 11:15 PM
filipinoy's Avatar
filipinoy
I have 20s and Eibach pro kit springs on my g37x coupe. I haven't scraped and only got rear camber and toe kit. Fronts are not in specs but pretty close
Old May 4, 2015 | 02:32 PM
Dillybar12's Avatar
Dillybar12
What do you mean by in specs?
Old May 4, 2015 | 03:26 PM
filipinoy's Avatar
filipinoy
When you get an alignment after lowering
Old May 4, 2015 | 04:08 PM
Dillybar12's Avatar
Dillybar12
Do you ever switch back to your stocks ever?
misc
17
Dec 24, 2019 05:13 AM
PearlPereZ
Jun 21, 2016 06:35 PM
cconklin2
Jan 9, 2016 07:21 PM
phamous
Picture Share G Coupe
Sep 30, 2015 02:15 PM
jfisher
Sep 13, 2015 07:58 AM
