Help Fortune Auto 500 rear coilover noise
Over the past two weeks I have been trying to figure out where this persistent, subtle knock and rubber squeak are coming from. I properly installed a set of OEM style Fortune Auto 500 coilovers. The front is perfect, but when driving under 20mph with the radio off I hear this chatter. I have revisited the rear 4 times now and narrowed the issue down to the damper. Any ideas on how to resolve this? I went with FA because I didn't want to have to deal with the same type of noise people are getting from BC.
Brakes & Suspension - MyG37
My rears make some noise too, but I figured it was the camber or sway bushings squeaking. To me it's barely audible at low speeds with the radio off and no one talking (that combo is rare in my car). I haven't dug in to find the source because it's not a big deal to me. I will say this I've owned BC coils on a different car (07 Altima 3.5 6MT) and they squeaked and did make noise (no camber kit on that car). Also they didn't ride as well as the Fortunes (different car, but still big difference). Overall I'm happy with the Fortunes so far.
Yup it is the right rear making noise. I am going to try lengthening the rear shocks a bit and see if I can get the noise to go away. I will post my results.
Yes, you put the stock bottom rubber spring mount and add the metal machined part that came with the coilovers for the bottom of the spring on top of it followed by the plastic washer and then the spring on top.
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
tite_tite
Aug 22, 2015 05:21 PM
MeatySock
Aug 14, 2015 08:25 AM
