KWV1 coilover install / recommendations for DIY
Old Apr 15, 2015 | 11:42 AM
stevo4756's Avatar
stevo4756
Question KWV1 coilover install / recommendations for DIY
Going for the big drop next week and was hoping someone that has experience with the installation processes could maybe make a few suggestions? I have done coilover installation before, just not on such an expensive vehicle so I want to be sure to get this right.
My main concern is that I have everything needed for this to go smoothly and hopefully creak/noise free.
Seeing as I have kwv1 I thought about purchasing an extra set of strut top hats, but after seeing the price I'll probably just swap them from OEM strut assembly because I doubt I'll ever go back to stock suspension.
Your thinking, get to the point already...
THE MAIN QUESTION :
Will I need or would you suggest I get replacement strut gaskets or can I reuse OEM?
Any other suggestions?
Thanks guys!
Old Apr 15, 2015 | 12:14 PM
terribleone's Avatar
terribleone
I re-used my strut gaskets with my V1's I have had no issues for a few years now. I would think if they are worn out or not seated properly you may get some squeaking (this goes for the re-use of the top hats too)?
Old Apr 15, 2015 | 02:03 PM
stevo4756's Avatar
stevo4756
As far as I can tell the top hats look to be good, but if they are original (85,000 miles) I guess I should reconsider replacing them... Ugh..
Thanks for the quick response !
Old Apr 15, 2015 | 10:20 PM
My OEM gaskets were in good shape when I installed my coils w/ about 35k on my G, they seem to be pretty durable gaskets. As long as they're not ripped during take off I think you could reuse them w/out issue.
Just be sure to PB blast that front lower strut nut the night before the install.
Old Apr 16, 2015 | 10:20 AM
stevo4756's Avatar
stevo4756
Sweetness I'll be careful with the gaskets.
” Just be sure to PB blast that front lower strut nut the night before the install."
I wouldn't have thought to do this the night before, great tip. Thank you Blnewt.
P.s. many pictures / reviews to come ! I'm probably going to do a build page since I have done numerous mods in the past few months since I bought the G. ( CAN'T STOP )
sLADe781
32
Nov 28, 2015 03:23 AM
Morgan Thompson
Aug 19, 2015 04:44 PM
cparise
Aug 19, 2015 01:51 PM
MeatySock
Aug 14, 2015 08:25 AM
JakeG37
Aug 13, 2015 11:19 AM
