2010 G37x Swift springs
Old Dec 6, 2014 | 11:28 PM
G37Genova's Avatar
G37Genova
So I looked at many of the lowering options out there and have came to the conclusion coilovers and air bags are just too expensive. Ive seen a lot of guys love swift springs and say they didnt need a camber kit. My only real question is, is there any problems with the stock shocks or struts when you drive on swift spings for an extended period of time? I dont see the point of buying springs if you have to constently replace you shocks and struts. Ive heard you put a lot of tention on your stock struts when using lowering spings but im not 100% sure could anyone that has had swift springs for a while shed some light on this? Thanks
Old Dec 7, 2014 | 12:29 AM
Dj1ofDet's Avatar
Dj1ofDet
There are no issues that I've come across with driving on the Swifts for an extended period of time, as I did for nearly 13k miles. On the other hand coilovers can be had for under $1000 (especially used). You don't NEED a camber kit with these springs, but you will be out of factory spec. It shouldn't chew your tires up too quickly.
Old Dec 7, 2014 | 10:26 AM
G37Genova's Avatar
G37Genova
Ok that helps a lot thanks. How much faster does it really chew through your tires though?
Old Dec 7, 2014 | 11:19 AM
RexHavoc's Avatar
RexHavoc
Should be negligible. Just to be safe I do a four wheel rotation every 3k when I change the oil.
Old Dec 7, 2014 | 05:08 PM
Jethro's Avatar
Jethro
It is going to wear the struts out faster with lowering springs. The exact amount is really unknown and varies.
I was probably in minority of not liking swift's on my xS sedan, but I bought my car used with like 40k miles and ran them for about 15k. Maybe my struts were already going before the swift's finished them off...
Old Dec 7, 2014 | 09:48 PM
Dj1ofDet's Avatar
Dj1ofDet
I ran my original front tires for around 50k miles and rears for 55k (they were really chewed up upon replacement), including 13k with the Swifts on.
Old Dec 7, 2014 | 11:14 PM
botlfed98's Avatar
botlfed98
did you ever have an alignment done?
Old Dec 8, 2014 | 12:30 AM
G37Genova's Avatar
G37Genova
Id have analignment done and i think im gonna do aftermarket struts too just to be safe since i also bought my car with 42k miles. Now shes at 57 time flys
Old Dec 8, 2014 | 11:41 AM
Dj1ofDet's Avatar
Dj1ofDet
I always had an alignment, but without a camber kit, I couldn't get the wheels in spec. I chose to chew those tires up, and when I replaced them I installed a camber kit.
Old Dec 8, 2014 | 11:48 AM
ANMVQ's Avatar
ANMVQ
I have swifts on my 09X and nothing but good things! Comments on the drop ( Not too aggressive) so bumps and driveways aren't hard to get into. I'm on my stock shocks ad struts and at 68k on them, 9k on swifts, No issue other than a rear link broke, replaced under warranty
Old Dec 10, 2014 | 08:51 PM
G37Genova's Avatar
G37Genova
Good to know.And did you need a camber kit or anything?
Old Dec 10, 2014 | 10:41 PM
Dj1ofDet's Avatar
Dj1ofDet
You can all but count on needing a camber kit with Swifts. It won't be absolutely necessary, but recommended to get max life out of your rubber.
G's
Nov 5, 2023 12:01 PM
m3clubracer
Sep 11, 2016 09:01 PM
Broski28
Feb 9, 2016 11:50 AM
drewfinity
Sep 8, 2015 09:10 PM
