Well Just bought Swift springs
Old Apr 29, 2014 | 06:45 PM
  #256
HMG37's Avatar
HMG37
Originally Posted by grojas112
Here are my specs after alignment with swifts installed
Are the front and rear camber kit required
Attachment 103982
I recently dropped my 2012 G37xS on Swifts as well, and I got the same results. -2.0 camber in the front, and it can't be adjusted.
I was under the impression that with Swift springs I would need NO camber kits, or only rears if I wanted.
Old Apr 29, 2014 | 06:56 PM
  #257
grojas112's Avatar
grojas112
Just had another alignment after the SPC camber kit. Much better
Old Apr 29, 2014 | 07:07 PM
  #258
Attachment 104015
That's one of the best alignment sheets I've seen, even a bit better than mine.
Old Apr 29, 2014 | 07:16 PM
  #259
So what's going on here, Newt? These guys coming out of the woodwork with negative camber way out of spec on Swift Springs... do you think this is an AWD thing? Or is it just coincidence, and every car is unique?
Old Apr 29, 2014 | 07:27 PM
  #260
AroundTheG37's Avatar
AroundTheG37
I'll be getting my alignment this week so we'll see whats up. I will say if they can't bring it close to spec I will have to wonder why I went with swift in the first place.
Old Apr 29, 2014 | 07:30 PM
  #261
NeverEnough007's Avatar
NeverEnough007
My stock suspension xs sedan is just barely within range. Any further sagging in the suspension and I will need a camber kit to keep it in.
Old Apr 29, 2014 | 07:36 PM
  #262
Because I want the maximum amount of negative camber I can get while still in range of specs that won't shred my tires, and I want this to pull in the top of my poked rims. That's why I went with Swift, for the minimal drop and OEM like feel.
Old Apr 29, 2014 | 08:15 PM
  #263
AroundTheG37
I'm hoping for .8 on the rears and .5 for the fronts. We'll see.
Old Apr 29, 2014 | 08:24 PM
  #264
You mean -0.8 and -0.5, and yeah that would be perfect.
I'm probably going to wait a 100 miles or so before getting the alignment.
Old Apr 29, 2014 | 08:25 PM
  #265
AroundTheG37
Of course I do and if someone interpreted that the other way then they got bigger fish to fry.
Old Apr 29, 2014 | 09:16 PM
  #266
Indeed. Like the irresponsible crazy of photographing loose springs upside-down.
Old Apr 29, 2014 | 11:09 PM
  #267
AroundTheG37
and I'm the fickle one.........
Old May 1, 2014 | 12:12 AM
  #268
AroundTheG37
Turns out the rubbing noise wasn't coming from the front so looks like I need to take out my wheel liner in the rear. Yay.
Old May 1, 2014 | 12:15 AM
  #269
Drive Clean's Avatar
Drive Clean
If it helps any I've got a AWD sedan and my camber was at -2.0 in the front and -1.5 in the back. The shop said the fronts were maxed out, but they were able to adjust the rear by a little bit. Toe was completely in factory spec though
Old May 1, 2014 | 08:02 AM
  #270
rm2342's Avatar
rm2342
We need more pictures in this thread of the drops with the specs.
