Thats odd, have you had a chance to mimic the sound on your own? Full turn? over bumps? I feel like my front is a bit lower than swifts and Im running 245/40/19--no rubbing.
It happens at low speeds around 20-30 mph on the right side and only with passengers in the car. I'm pretty sure it's the front because when my I had my previous tires on there was no rub to be found/heard.
Required, no but you'll pay for those camber kits over the long term in worn tires. I'd get them.
Good call. When I was researching my lowering options I saw an overwhelming amount of people saying you can get away without. I think the new consensus should be that if you lower your car, the proper way to do it is with camber kits. The G37 has basically no adjustment in the front and I have seen so many threads where lowering springs are installed and a week goes by without any abnormal tire wear and then the assumption is made that everything is alright. I see just as many threads saying "Oops the inside of my tires are worn to the belts" maybe I need a camber kit. I came from a forum of a much cheaper and older car with factory front camber adjustment and it was frowned upon to run lowering springs without a camber kit. At the end of the day the choice is in the hands of the owner of the car but it's nice to see when people are equipped with the right information.
