Alignment woes.....
Old Sep 16, 2013 | 09:21 PM
  #46
TVPostSound's Avatar
TVPostSound
Ok I talked to a buddy of mines who I call the suspension guru. Anyways I was wrong about the lockout washers. They ONLY work in conjunction with toe arms. Which means true coils..
Other alternative option is to take your spc toe kit to a machine shop and have them machine you new eccentrics. Read here more about it
MY350Z.COM Forums - View Single Post - Any other toe bolts out there besides SPC?
Another option is to buy the SPL titanium rear mid link. Which is insanely expensive.
Pretty much three choices
1. True coils with lockout washers + toe arms (which he say is the best)
2. Have shop custom machine you new eccentrics (cheapest option)
3. Buy those SPL titanium rear mid link to have complete control over toe (most expensive it seems)
https://www.myg37.com/forums/3548463-post1.html
Or have offset lockout plates made to match your eccentric position!!
Then adjustable traction rods for micro adjustment.
Old Sep 16, 2013 | 09:26 PM
  #47
Topher9425's Avatar
Topher9425
Now are traction rods the same as toe rods? Either way, the basket needs to go, correct?
Old Sep 16, 2013 | 09:57 PM
  #48
Originally Posted by Topher9425
Speaking of true coils......Are Stance GR+ (Stance SS) true coils in the rear? Planning on buying a set, and damn google images shows both for our cars. lol
Might check this link, nice price for sure, give 'em a call they should be able to tell you, I believe they are true coilovers.
STANCE Super Sport Coilover Kit - Nissan 370Z / G37 - Enjuku Racing Parts, LLC
Old Sep 17, 2013 | 12:18 PM
  #49
TVPostSound
Yes.
The basket stays, look at the pictures on my link.
Old Sep 17, 2013 | 01:21 PM
  #50
Topher9425's Avatar
Topher9425
But you state that these are only good for mild drops with swift and/or eibach, or else its too low.........
Old Sep 18, 2013 | 08:31 PM
  #51
TVPostSound
The offset I used was only good for mild drops, as Im selling a second set I made.
You can make a set with double the range.
Old Sep 18, 2013 | 08:41 PM
  #52
Topher9425's Avatar
Topher9425
No idea where a machine shop is around me bro.....hook me up if you have a connection, and I will gladly buy them off you. PM me for details
Old Sep 18, 2013 | 08:48 PM
  #53
Topher9425's Avatar
Topher9425
My Stance SS coilovers should be on the way by Friday or Monday.....whew hew, so exciting!
Old Sep 19, 2013 | 02:28 PM
  #54
Need 4 Speed's Avatar
Need 4 Speed
@Topher, great choice for I have them as well. Enjoy Brother!
Old Sep 19, 2013 | 02:38 PM
  #55
quakerroatmeal's Avatar
quakerroatmeal
Since you are switching over to the true coilovers now why not go with lockout washers + toe arm setup with it?
Old Sep 19, 2013 | 05:22 PM
  #56
Topher9425's Avatar
Topher9425
Quaker, I plan too.....for now, I have my Toe locked and my camber sitting at -2.9 bro.
Old Mar 31, 2014 | 12:06 AM
  #57
JC-RH's Avatar
JC-RH
I went with Stance SS true type too. What did you finally do about the toe arms (traction arms)? I have the SPC toe bolts now. They worked great, but I still need a tiny bit more adjustability to get my toe where it needs to be (slight toe in).
4DRZ
Engine, Intake and Exhaust
12
May 18, 2017 11:25 AM
rk325
Oct 13, 2015 01:51 PM
m3clubracer
13
Sep 28, 2015 09:54 AM
rgonz
Sep 11, 2015 04:07 PM
jfisher
Sep 9, 2015 04:17 PM
