Help SPC arms contacting fender, Lets see your solutions?
Old Mar 18, 2013 | 02:07 PM
  #31
surfwagon's Avatar
surfwagon
Originally Posted by mj_39
Hey Guys, just got the call back from Johnny at SPC. He has confirmed that surfwagon and my arms are the NEWEST version front camber arms. He stated that the red boots are all older version arms. Newest arms are black boots and that the no longer use the red boots
Huh, that's interesting. I'm surprised that anything under 26.5 was making contact with the fender.
Old Mar 18, 2013 | 04:15 PM
  #32
eksigned's Avatar
eksigned
For the record, SPC hasn't sold the 2nd generation in years. The third and final generation should come with a BLACK boot. Red was once upon a time, way the hell long ago. I just ordered my set through SPC directly via our vendor account. Spoke with Jeff and he confirmed this.
Old Apr 10, 2013 | 10:25 AM
  #33
TVPostSound's Avatar
TVPostSound
The 3rd generation was just released late July 2012.
The announcement was early July 2012
I sent my 2 gen in directly to SPC for the 3rd gen upgrade. Has a red boot.
Old Apr 10, 2013 | 04:31 PM
  #34
Ahh, the plot thickens
Old Apr 10, 2013 | 05:07 PM
  #35
mj_39's Avatar
mj_39
I referred Johnny from SPC to this thread, they looked at your pictures and mine and CONFIRMED mine were the newest arms? Are they lying to us? What's going on here?
Can any one confirm what's going on here. I believe what TvPostSound is saying however SPC is saying otherwise
Vendors can you chime in?
Old Apr 10, 2013 | 05:23 PM
  #36
TVPostSound
So Johnny sent me a set of older arms???\
EDIT:
I just spoke with Jeff at SPC, the 3rd gen arms have both red and black boots on the bj.
They just recently changed over to black boots.
To confirm the 3rd gen had a revised construction, and the rod is welded at 3 sides to the flat metal plate.
Old Apr 10, 2013 | 05:30 PM
  #37
mj_39's Avatar
mj_39
When I asked him about yours, that's what he implied... "any arms with red boots are all older model arms, newest arms all come with black boots"
Exact quote from Johnny @ SPC
Old Apr 10, 2013 | 05:35 PM
  #38
TVPostSound
Then Jeff and Johnny need to confer!!
The new model has better welds and longer round stock, this is mine, same as yours above!!
We both have the newer versions!!
IMG_0312.jpg?t=1343955090
This is yours, same welds:
Old Apr 10, 2013 | 05:39 PM
  #39
mj_39's Avatar
mj_39
K good!! Haha that's all that matters
Old Apr 25, 2013 | 04:15 PM
  #40
hipoCBR's Avatar
hipoCBR
so is the rear camber kit.toebolt even necessary. or is that over-rated??
Old Apr 25, 2013 | 09:35 PM
  #41
Not over rated at all, but if you're only dropping 1.3" or less you should get in spec or close enough. If you're dropped more than that you'll have a tough time keeping both camber & toe in spec. Be prepared to chew up some tires if your toe is out. Getting just the rear toe kit (about $60) might be enough to get both in spec if you're not too low.
Old May 1, 2013 | 06:03 AM
  #42
JMS2000's Avatar
JMS2000
Question Rear Toe Kit
Is it a big deal to widen the slot for the toe bolt? It doesn't sound like it's reversible if for some reason it gets messed up during the install. Do you think I can get away with just installing the camber link? Drop will be mild.
Old May 1, 2013 | 09:12 AM
  #43
A mild drop you might get everything in spec without any camber/toe kits. How mild a drop are you considering?
And no, the toe slot isn't reversible without having to refab the support.
Old May 2, 2013 | 06:04 AM
  #44
JMS2000's Avatar
JMS2000
I just want to close the fender gap all around, with the front a little lower than the rear. I don't have exact ride height measurements in mind, but from what I've read on here and seen in other people's pictures, it'll probably be in the 26.5" to 27" range, give or take.
Landshark
Jan 16, 2020 10:25 PM
jfisher
Apr 25, 2017 01:22 PM
m3clubracer
Sep 16, 2015 03:08 PM
jfisher
Sep 8, 2015 04:16 PM
