Install Eibach pro kit 6388.001/2 F/R
Old Sep 16, 2015 | 09:34 AM
m3clubracer's Avatar
m3clubracer
Purchased at Stillen along with SPC toe adjusters for my '10x.
Here you can see the actual drop before and after. I did the rears first and the fronts ~4 hours later. I suspect maybe the rears settled a bit in 4 hours. The fronts look lower than this today (Wednesday) as this was done on Saturday and the after pictures were taken immediately after the fronts installed. I will take measurements again Saturdayish for a week of settling. Yes, I measured only one side of the car, fully laden as the manual says (RTFM please), and from the floor to the fender (stupid idea because not everyone's tires are the same dia or pressure) instead of to the center of the wheel so everyone would have the same measurements. Your results may vary.
File Type: pdf
Old Sep 16, 2015 | 02:04 PM
Nice way to do it, good job!
As far as measuring from the ground to the fender, still decent as long as you keep diameters in mind, most are pretty close to oem so maybe a 1/4" here & there, but a good point you've made
Old Sep 16, 2015 | 03:08 PM
m3clubracer
Thanks. Apparently I cropped the wrong arch height. I used the RWD and not AWD table?
Ricio1991
12
Apr 21, 2022 01:39 PM
G37xhibeet
Nov 15, 2016 09:29 AM
BANNISTER
Dec 10, 2015 04:14 PM
Ipp391
Aug 28, 2015 09:27 AM
cparise
Aug 19, 2015 01:51 PM
