Cusco Strut Tower Brace Installed
I just hung up the phone with Yuki at CUSCO USA. He said that the installation of the G37 strut tower brace is to be performed with all 4 wheels on level ground and the suspension fully loaded. Cal him at (714) 907-0033. Beware he has a very heavy Japanese accent that may be hard for you to understand. So I made sure to get him to clarify and repeat it more than once to make sure I wasn't misunderstanding him.
Mattlorentzoe (09-16-2015)
![Smilie](https://www.myg37.com/forums/images/smilies/smile.gif)
I just want it done right and for everyone else to know the right way, whichever way it is. Correct info for everyone is much more important than anyone being right. I understand the logic of installing with the suspension unladen but all the instructions that I'm familiar with state to install it with suspension loaded. There must be a reason for that.
just shows cusco doesnt know imo, installed my gt spec on a lift which is the way its suppose to be done like bluestickg was saying. if you watch you car get lifted as it comes off the ground the the strut mounts will get further away from each other. it was the only way we could get mine mounted cuz on the ground it was too close and couldnt squeeze the bar in. being able to install the cusco while your car being on the ground confirms my opinion that the cusco is more show than performance and if people actually got the gt spec they would agree with me that it is better than sway bar upgrade which is what i have found and noticed
Cusco is widely esteemed as one of the premier suspension companies in the world. They are well-reputed for their high quality components and that renown is supported by their track record. That reputation was not built on "show." I'd be willing to bet the representative with whom Jeremy spoke is well-schooled on the components his company manufactures.
![Dunno](https://www.myg37.com/forums/images/smilies/dunno.gif)
But I was wondering the same thing that when you lift the car, won't the actually coil assembly drop out a bit?
Al Czervik (11-30-2015)
I'd still like to see something from Cusco in writing (in English
![Icon17](https://www.myg37.com/forums/images/smilies/icon17.gif)
like i said as you lift the car the mounts get a little further apart and had to be done in order to install mine. if your able to install a strut bar not lifted the car is already compressed and wont completely stiff. that might be why you didnt notice a difference from the strut bars because you didnt install them with a lift. also i believe you installed your sways first and that prolly stiffened it quite a bit and the strut was then minimal. i did the strut first and sways later and the sways were minimal so in that case im guessing which ever one you do first will have to most effect. (logical) but for those with neither and want to pick which one i suggest the cheaper one lol all good
#29
Thanks for the above-and-beyond clarification BB.
I'd think that on level ground, the towers are where they're supposed to be, and the strut brace helps keep them there. If mounted when raised off the suspension, you'd be keeping the towers in not-quite-right position.
