KW coiloer intall time/cost
Old May 21, 2012 | 08:10 PM
rks's Avatar
rks
KW coilover install time/cost
I'm being quoted 4-5 hours or $350 - $450 which seems extremely high since springs cost me about $150 to install and it seems like coilovers may be simpler because you don't need to compress springs. What would be a fair counter or can I do this myself with basic mechanical knowledge and tools?
Old May 21, 2012 | 08:15 PM
Rad_Slinger's Avatar
Rad_Slinger
I was charged $350 for a performance shop to install my coilovers.
They're still going to have to compress the springs for the install.
Sounds about right unless you know someone. Took 4 hours for the install.
Old May 21, 2012 | 08:46 PM
SwissCheeseHead's Avatar
SwissCheeseHead
I did it at home with basic tools. I spent about 6 hours on the install but that was with installing front and rear camber kits and really taking my time. Doing it again, I could do it in 4 -5 hours. If you have the time and a variety of tools, it can be done. Just plan a weekend for it. Must haves are breaker bar, impact wrench and PB blaster.
Old May 21, 2012 | 08:59 PM
Gville37's Avatar
Gville37
that is about the same price range i was charged. i didnt have the tools, time, and general knowledge to do the install so I went to a professional.
IMO, I had an expensive upgrade that I wanted to get installed correctly and the odds of the shop messing up is a lot less than me messing up.
sadly everytime i purchase i forget the install fees(if i cant do it myself).
Old May 21, 2012 | 09:02 PM
Modme's Avatar
Modme
Use the labor fee to buy yourself some tools. There are some very good DIYs in the forum. If you take your time and do some research ahead of time, you will do a better job than the shops.
Shops dont take the time to torque the bolts according to factory specs. Everything is done with a impact gun.
Old Jun 1, 2012 | 04:06 PM
datboiroy's Avatar
datboiroy
I was quoted $500 to install my KW V3's and SPC front and rear camber kits. Still debating to do it myself with friends or get it done at a shop.
Old Jun 1, 2012 | 04:20 PM
soundmike's Avatar
soundmike
Coilovers are a whole lot simpler to install, but extra time is spent trying to finalize the height.
Plus, don't you need to compress the springs on the KW to put the OEM or aftermarket top hats on? (i.e. some KW's don't have them)
Either way, you can certainly DIY this. Just make sure the car is on sturdy jack stands and you PB blast the daylights out of every nut and bolt you plan to loosen.
Old Jun 19, 2012 | 11:52 AM
mpw5097's Avatar
mpw5097
Yes that is correct.
I did the install in just a few hours, however, getting the ride height even at all corners took a bit longer.
Old Jun 19, 2012 | 02:11 PM
slickg37's Avatar
slickg37
I was quoted $400-600 to put on springs (they said 4-6 hours of work). I thought that was pretty high for just springs. I am going to sell my springs and wait to get coil overs. So that price doesn't seem bad.
My buddy has a lift and all the tools needed and then some....but I think for suspension I would rather have a shop do it.
Old Jun 19, 2012 | 02:18 PM
B L U E S L A T E's Avatar
B L U E S L A T E
I'd rather spend that money on a set of nice tools and install them myself.
And whoever quoted you $400-600 for springs are on some serious crack.
Old Jun 19, 2012 | 02:46 PM
slickg37's Avatar
slickg37
Believe it or not...two different shops did....So I am going to do it right and save up for some KWs
Old Jun 19, 2012 | 03:45 PM
GraphiteG37S's Avatar
GraphiteG37S
I got quoted $375 for my coilover installation, so instead I did it myself.
Old Jun 19, 2012 | 06:25 PM
Gville37's Avatar
Gville37
plus one here. about the same i paid. worth it. i was at the shop and a customer rolled up in his lexus lfa....so il call that an even trade hahah
side note...also had spc front and rear installed same time
Old Jun 19, 2012 | 06:42 PM
xeddyboi420x's Avatar
xeddyboi420x
$100/hr 3 hours = $300
but they took all day with an alignment
jroyalty7
Jul 27, 2015 07:39 PM
photocat
MODDING 411
18
Jul 3, 2015 08:53 AM
phamln
Sep 4, 2014 10:52 PM
budiu22
Intake and Exhaust
Jun 10, 2014 06:41 PM
SEATOWNBOY
19
Oct 13, 2013 11:40 PM
