Hotchkis swaybar weight
Old Aug 9, 2011 | 12:35 AM
superjer2000's Avatar
superjer2000
Originally Posted by Okita240
Use the ramps, and not the jackstands. The load is zero for the swaybars when the car is sitting on ground. I also needed to torque the front endlinks higher than specified. I had it at specified torque and the nut became loose during test drive.
That's interesting. I just installed my coilovers this weekend and noted the first line of the BC Racing manual for the G37 which stated:
"Raise both front together and secure jackstands. Having both wheels in the air will remove all pressure on the sway bar."
When I only had one wheel in the air the sway bar wouldn't move so I assumed these guys were correct. I know that when I installed my Hotchkis sway bars I did it with jack stands and there were no issues moving the sway bar around so I can attest that there is little or no load when the wheels are off the ground but I can't say that what Okita is saying is incorrect either as I never tried it with ramps.
Old Aug 9, 2011 | 02:31 AM
Okita240's Avatar
Okita240
That is interesting superjer2000. Maybe the endlinks have enough play to deal with either one of the scenario. I might still go with the ramps for stability when working under the car and I think its easier to just drive up the ramp.
Old Aug 10, 2011 | 12:19 AM
Kuro's Avatar
Kuro
Thanks for the info
Old Aug 12, 2011 | 07:18 PM
Dirt Dog's Avatar
Dirt Dog
Originally Posted by Rickblkg
Middle hole
Thanks, middle hole it is.
I'll try the ramps first just cause they are easier and if there is still pressure on them, I'll just jack it up a few inches.
Old Aug 12, 2011 | 11:01 PM
superjer2000
I would way have rather used ramps than the jackstands when I did my install. There is something very unnerving about working under a car when it is supported by jackstands.
Old Aug 13, 2011 | 12:18 AM
Alpha Ice's Avatar
Alpha Ice
Minnesota G owners
Just have some quality jack stands
Old Aug 13, 2011 | 10:24 AM
hollywhip's Avatar
hollywhip
And a Good Life Insurance Policy on yourself for the Wifey
Old Aug 13, 2011 | 05:59 PM
Dirt Dog's Avatar
Dirt Dog
Finished up today and they are awesome. The G takes corners like it is on tracks now.
Used the ramps and the bars were completely unloaded, so the hardest part was fitting my fat a&&% under the car to disconnect the exhaust.
Kojack
Oct 9, 2015 05:53 PM
djdiskino
Sep 29, 2015 07:18 PM
Slapshot1
Sep 27, 2015 08:40 AM
GFTW
Sep 19, 2015 03:52 PM
