Akebono swap...brake lines?
Old Aug 15, 2010 | 10:11 AM
EnviedG35's Avatar
EnviedG35
I have an 08 35 sport with the 13" front/rear brakes. I think rather than simply replacing rotors and pads im going to go with the Akebono's. From what i have gathered, the caliper itself is a direct bolt on, but what about the brake lines? Do i need seperate brake lines for the caliper aside from the ones that are currently on the car?
Old Aug 15, 2010 | 11:58 AM
Q8y_drifter's Avatar
Q8y_drifter
I was in exactly the same position as you. Needed to replace the rotors and pads on my HR sedan. Went with the Akebono BBK along with stainless steel lines. Forget the stock rubber lines, the SS are better and more consistent. I highly suggest you upgrade the lines as well. While you're at it, go with better pads too. The stock ceramic ones are just like the stock 08 G35S with weak initial bite.
I got my kit from Concept Z Performance. You can mix and match anything you want in the kit. If you want anything specific then just PM Coz@CZP and tell him what you want in the kit. He'll also give you a forum discount. I think they also offer caliper painting services now.
Brakes Parts, Upgrades, and Accessories
Old Aug 15, 2010 | 01:43 PM
myk1013's Avatar
myk1013
Yeah,
might as well change to SS brake lines while your at it.
Old Aug 15, 2010 | 05:44 PM
JohnnysG's Avatar
JohnnysG
hey q8drifter.. if you dont mind could you pm me the pricing of what you did? i have the nonsport model and want to upgrade as well to the akebonos
Old Aug 16, 2010 | 12:07 PM
APRacing-ChrisB's Avatar
APRacing-ChrisB
If you are getting the hard pipes that go from the caliper to the upright, you can use aftermarket SS lines like those from Goodridge. Just be sure to order the ones for the Sport model, not the standard brakes model.
If you didn't get the pipes, get them. Nothing is stiffer than steel tubing. Since the Akebono's are not the stiffest 4-piston calipers around, they need all the support they can get from the rest of the components.
Chris
Old Sep 11, 2010 | 01:42 PM
amg35's Avatar
amg35
Chris,
Thanks for the info and please forgive my ignorance. I am aware of stainless brake lines, but what are the hard pipes you mention?
Thanks,
Allan
Chris
Old Sep 12, 2010 | 01:05 AM
Weiboy718's Avatar
Weiboy718
Chris
hey Chris! are you with Stillen or AP Racing?
Old Sep 13, 2010 | 02:34 AM
APRacing-ChrisB
Originally Posted by amg35
Chris,
Thanks,
Allan
The bent stainless tubing that is connected to the caliper should not be removed. Only the rubber lines should be replaced, which is what we had Goodridge do.
Chris
Old Sep 13, 2010 | 02:35 AM
APRacing-ChrisB
I am with Stillen's High-Performance Brake Division, engineering partner and exclusive road-car products distributor for AP Racing in the USA.
Old Sep 13, 2010 | 10:47 AM
amg35's Avatar
amg35
Thanks Chris.
So if I buy a set of the Goodridge lines and leave everything else OEM, I will be good?
Thanks again.
Chris
Old Sep 13, 2010 | 11:26 AM
Weiboy718's Avatar
Weiboy718
Cool, I asked Josh about you and he told me you're the brake manager.
My car is down there at Stillens facility getting a set of goodies That white G37 is mines.
Old Sep 13, 2010 | 11:48 AM
APRacing-ChrisB
Correct! Make sure you use an upgraded fluid, like AP Racing Formula 5.1.
Chris
Old Sep 13, 2010 | 11:51 AM
amg35's Avatar
amg35
Thank Chris.
Time to do some shopping, after the boss (wife) leaves my office.
Take care,
Allan
Chris
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
ck1109
Oct 15, 2015 11:06 PM
rk325
Oct 13, 2015 01:51 PM
faze2988
Oct 7, 2015 12:05 AM
Allboutcali
Sep 26, 2015 03:43 PM
