changing rotors????????????????
I need to know how to change my front rotors on my g37sport 2008. do i need special tools and can i get directions anywhere?
To keep you from getting told to search with each new post, you might want to download the Factory Service Manual here:
Knowledgebase - G Coupe - Infinitihelp.com
You have register, but worth it. Noticed they now have the 2009 as well.
DIY!
its for the 370z but they use the same brakes
2009 Nissan 370Z: DIY Brake Pad and Rotor Change, Part 2 | Long-Term Road Tests Blog on Edmunds' Inside Line
its for the 370z but they use the same brakes2009 Nissan 370Z: DIY Brake Pad and Rotor Change, Part 2 | Long-Term Road Tests Blog on Edmunds' Inside Line
Great DIY, but still download the manual as it has all the factory spec torques for all the bolts and I do not recall anything at 98lbs (may be wrong hence use the manual).
DIY!
cyberone28
Sep 25, 2015 02:31 PM
photocat
Sep 3, 2015 01:46 PM
