Help SPC Front Camber Kit Rattle
Old May 5, 2009 | 03:31 PM
  #166
HamstersG's Avatar
HamstersG
Alignment scheduled for 5/12 and will be getting camber range measurement for front per discussion with SPC.
Old May 5, 2009 | 03:37 PM
  #167
Triple_X's Avatar
Triple_X
so is SPC going to release a new kit all together? any eta if so?
Old May 5, 2009 | 03:42 PM
  #168
HamstersG's Avatar
HamstersG
From my discussions, I think they are going to use the G35 arm as is.....not 100% positive. I think the only thing that needs some change may be the caster/camber adjustment assembly. Jeff needs my camber info. I was being too slow so he called me and poked me....I was traveling so just running behind.
Old May 5, 2009 | 03:55 PM
  #169
Triple_X's Avatar
Triple_X
thanks for the info and for helping resolve this issue. I need a front kit decently soon due to bad camber but I am going on vacation end of next week so should buy me more time
Old May 6, 2009 | 08:58 PM
  #170
oOmikeyboy's Avatar
oOmikeyboy
Nice. Im gonna slam my car soon and i wanna get this kit.. but not with the issues it has now.
So its almost certain theyre going to re-engineer the G35 arms for our cars, rather than using the G37 SPC arm?
Old May 6, 2009 | 10:56 PM
  #171
HamstersG's Avatar
HamstersG
The arm that I have is part number 72130 which was designed for the 2007-2008 G35/G35X Sedan. It is not the same arm as for the older G35 models.
If they go with this arm for the G37, there should not be any change to the arm. Take a look at this picture. It fits almost perfectly up in the pocket of the fender.
The potential issue that both Finagle69 and I have brought up is that there might be a better design for the camber/caster mechanism.
Old May 11, 2009 | 04:03 PM
  #172
THMotorsports's Avatar
THMotorsports
Guys, gals, if anyone needs more info as well, hit me up. We are on this case with SPC to see what will happen. I believe the G35 arms will be used for you all as they have minimal issues currently.
Old May 11, 2009 | 04:11 PM
  #173
Triple_X's Avatar
Triple_X
^^ any idea if the g35 arms will fit the same on an X coupe? Not sure if anything is different even, just want to be sure...
Old May 11, 2009 | 09:54 PM
  #174
machinist's Avatar
machinist
Yeah, I'd be interested as well in the x coupe. Man, I know we've gotta be patient, but I'm surprised it's taken SPC this long to address this issue.
Old May 11, 2009 | 10:02 PM
  #175
HamstersG's Avatar
HamstersG
Not all SPC. Getting my alignment and camber range measurement tomorrow.
Old May 12, 2009 | 07:21 PM
  #176
JLai's Avatar
JLai
Update please.
Old May 13, 2009 | 12:08 AM
  #177
HamstersG's Avatar
HamstersG
Got my alignment today and here are the results.
Caster:
Spec: 4.83 deg + or - 0.75 deg
OEM Arm in 9/2008 with Eibach Pro-Kit, Left 5.1 deg, Right 5.1 deg.
G35 Arm today with -0.5 deg caster adjustment, Left 5.0 deg, Right 4.7 deg
Camber:
Spec: -0.42 deg + or - 0.75 deg
OEM Arm in 9/2008 with Eibach Pro-Kit, Left -1.3 deg, Right -1.7 deg.
G35 Arm today with -0.5 deg caster adjustment and Eibach Pro-Kit, Left -0.5 deg, Right -0.5 deg
Net Correction:
I set the camber adjustment to the max positive adjustment before I went in. This took me from -1.7 deg on the OEM arm to -0.5 deg on the G35 arm for an improvement of +1.2 deg.
So bottom line is that with an Eibach drop (or something similar), the shorter G35 a-arm (SPC #72130) compared to the G37 Coupe a-arm (SPC #72135) will get you back to near nominal setting if you so desire and with no fender clearance problems.
Another way to look at it is to look at the camber measurement you have with your OEM a-arm from your last alignment and take off about 1.2 deg to see where you will end up.
I just emailed this to SPC so would expect to see something official from them in the not too distant future, but that is all I know for now.
Old May 13, 2009 | 12:28 AM
  #178
machinist's Avatar
machinist
Hamster wow! Thanks for taking the time and doing all of this. I'm looking forward to see SPC's response. I still have the front arms which I have to send back to Andy and see by the look of it getting the G35 arms as per your suggestion since I'm dropped on Eibach for my x coupe
Old May 13, 2009 | 01:01 AM
  #179
JLai's Avatar
JLai
^ Thanks for the specs!
Quick question: If I understand you correctly, we should leave the G35 arms on max positive adjustment to be near nominal? (Just trying to figure out where to set it at during the install...before an actual alignment)
Old May 13, 2009 | 12:15 PM
  #180
finagle69's Avatar
finagle69
set it to the maximum positive adjustment point.
you can see from my numbers that mine are on max as well.
