People who have rattling issues with the BC Coilovers PLEASE POST IN HERE!!!!
Old Sep 6, 2008 | 03:45 AM
  #106
G37RacerX's Avatar
G37RacerX
I've got this nagging feeling that the knocking sound I hear is something on my own car (and that of others) that may be making the noise. I think something about changing the struts to something other than stock has caused a problem. What I mean is I think I may have the same noise remain if I were to put the stock set-up back or even change out to a different set of coilovers. This is basically the conclusion that the suspension expert who last worked on my set-up had to say after spending a couple hours going over everything according to the latest instructions posted on this forum by Pete and even talking to Pete on the phone that day about everything it could be and what to check etc, etc.
I think something on the sensitive suspension of the G has been affected, this would also explain why it's only happening to the G37 guys and the 350Z's are all okay...
Old Sep 6, 2008 | 09:54 AM
  #107
SFLG35's Avatar
SFLG35
FGC Central Florida BOD
hey guys
here is the link to our thread on driver about it:
http://g35driver.com/forums/brakes-s...ml#post3403951
the first 2 pages get into a whole debate about linear vs progressive and have nothing to do with the orginal topic. then the ocg35 guy thinks hes god gift to earth when i start posting about the problem again and think im tryin to demean him.
anyways i dont think the problem lies with the changin of the supension. i have had stockers, then basics, then stockers again as i waited for my bc's, and now bc's and i have the noise. im pretty sure if i take the bc's off in the back the noise will go way.
another idea that come up is just to get rid of the pillow ball upper mount in the rear altogether and replace it with a rubber one, and see if the problem still occurs.
someone could also try taking their upper plate off of the shock and putting the stock one back on and remounting the shock and see if the problem is still there.
there is no one with this problem that is in the state of florida? if there is it would surely help pete figure out the cause, if you could meet up with him.
Old Sep 6, 2008 | 10:08 AM
  #108
G37RacerX's Avatar
G37RacerX
Not sure what you mean by stockers, then basics?, then stockers again but anyhoo...
It would be a PITA to swap back to stock but it sure would nearly prove something one way or another, IE, knocking gone=problem with BC's, knocking remains with stock suspension re-installed after previous BC install=something messed up with the G's suspension...
Old Sep 6, 2008 | 10:11 AM
  #109
SFLG35's Avatar
SFLG35
i had stock suspension, then tein basics, then stock suspension again, and now bc racing.
like i said i dont think it would mess anything up with the car.
it doesnt take that long to change out the rear suspension maybe 30 minutes.
Old Sep 6, 2008 | 12:22 PM
  #110
Kidcane's Avatar
Kidcane
Florida G Club
^^Whaddup Dan. I wish I could help but mine dont make any noise.
Its weird because now a few people say they have a clunk and then some say its a rattle.
Old Sep 6, 2008 | 12:29 PM
  #111
SFLG35's Avatar
SFLG35
hi chad!!
i think people are gettin the issues confused. its definately not a rattle.
a rattle woudl most likely because by people not having enough preload on their springs and the spring is a little loose.
the knock / clunk we are still trying to figure out.
Old Sep 6, 2008 | 01:24 PM
  #112
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Its not the car making the noise....
Old Sep 6, 2008 | 02:24 PM
  #113
Lou@Amplified's Avatar
Lou@Amplified
+1. I have no issue's with my coils. None whatsoever. I hope for everyone's sake that the problem is fixed though
Old Sep 6, 2008 | 02:34 PM
  #114
MaxToTheG37
No **** Shirlock you dont have BCs.... der der der....
Old Sep 6, 2008 | 02:40 PM
  #115
TomG37's Avatar
TomG37
Pete, can you please post contact info, I need to order a new rear spring perch, and I also have this awful clunk on the passenger side rear.
Old Sep 6, 2008 | 02:43 PM
  #116
Lou@Amplified
you still want the you know what?
yes my all mighty smart a$$..lol i was just backing your statement that it is not the car making noise.
Old Sep 6, 2008 | 02:58 PM
  #117
MaxToTheG37
hahah I know ... just bustin your chops.... I know your enjoying your coils... rub it in why dont ya....
Old Sep 6, 2008 | 07:51 PM
  #118
G37RacerX's Avatar
G37RacerX
Until it's known what exactly is causing the noise, I don't see how anyone can say with 100% certainty that is NOT the car. That is anyone except you Ben, you are smarter than the average bear...
Old Sep 6, 2008 | 11:26 PM
  #119
MaxToTheG37
Appreshinate cha....
Old Sep 9, 2008 | 04:04 PM
  #120
Pete@BC's Avatar
Pete@BC
Hey everyone,
After my last update I was getting everything ready to ship out those items that made way here. I got a call from a fellow board member with the rattle/knock noise. He's not to far away and we arranged to bring him in on friday late afternoon. I appreciate Dan for coming down to have a ride around and see if we can't finally take care of this. On the first drive out, it was noticeable on low speeds as he said. I tore down the back, checked the shocks, preloads and spring assembly. After 3 attempts and it getting a bit late, we decided we'd work on getting the car back here. I just made contact with Dan today and we are providing him with a rental and we'll have a week with his car to look over and trouble shoot it.
Some of the things we did:
Preload did not make a change
Changed to the older style design, no change.
Changed spring rate.
Took the upper ***** off just incase the extenders were making them pop
Dissassembled the rear shock and tested for any problems, nothing found
Checked the pillowball casing for any signs of it hitting. Found no signs
I did take the top plate off and checked the upper mounting position and found that the bolts are a bit smaller than the ones on our plates. The slop could allow for some play. I thought maybe this could cause the noise shifting. So I looked around the shop and found a perfect spacer. After finishing up, we thought this would have fixed it. It seems to have helped, but the sound is still there. To make sure we are all on the same field here. Dan's noise is generating up high, which leads me to believe it has to do with the top mount. Atleast this is where I will start concentrating trouble shooting first. One thing I want to verify is the 2 upper bolts for the rear top mount of the shock. This is just a thought, most of you having this issue was not immediately. Atleast that's what I've understood. What if using too much preload, or even a combination of preload, extra weight of larger wheels and tires are pulling down on those 2 studs and causing a uneven contact patch for the top plates. Minimal enough to cause it to seesaw and cause a rattle. Strut towers are known to mushroom on certain vehicles, so it is possible but needed to be verified. If any of you that have this rattle issue have a chance, take a look or shoot a pic of how the rear top plate is sitting on the car. I know Dan's had a slight gap.
Well, we'll have the car on thursday evening. So we'll keep everyone updated to the progress. Let me know if there is any questions I can help with.
