People who have rattling issues with the BC Coilovers PLEASE POST IN HERE!!!!
Old Aug 31, 2008 | 04:24 PM
  #91
TomG37's Avatar
TomG37
I'm hearing the clunking/knocking noise now, and I have a feeling my pre-load is off. Its very annoying and I hear it after every bump. Is it really bad for my struts, I really dont feel like blowing one?
Old Aug 31, 2008 | 05:01 PM
  #92
TerribleONE453's Avatar
TerribleONE453
so glad i didnt purchase these....
Old Aug 31, 2008 | 10:34 PM
  #93
TomG37's Avatar
TomG37
bump
Old Sep 4, 2008 | 01:39 PM
  #94
IP37's Avatar
IP37
for those with rattles..
try this.. stop your car on a downward hill. then let off your brakes to get the car rolling a little, then hit your brakes fast to stop the car quick. see if you hear anything then and if its the same sound or not
also, have you tried setting your dampening to something low like 10 clicks maybe to see if it makes any difference?
Old Sep 4, 2008 | 01:42 PM
  #95
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Im rollin on full soft right now... still gots dem rattlez...
Old Sep 4, 2008 | 01:56 PM
  #96
IP37's Avatar
IP37
try what i said about the hill
i raised the *** of my car 1/4" yesterday and turned the dampening up a bit and i had some rattles.. not sure if they were from the coilovers though. i still have to play with it some more, but i think they're gone now
i do hear something though if i do the hill thing. i'll go back out later and take out the jack and the crap that sits inside the spare and try again. probably have someone stand outside the car too and see if they can figure out where its coming from
Old Sep 4, 2008 | 11:43 PM
  #97
1BADV6's Avatar
1BADV6
Did anyone receive those parts from BC to try so we can work this out?
Old Sep 5, 2008 | 09:41 AM
  #98
Pete@BC's Avatar
Pete@BC
Ok fellas,
I need some names and address to get this going. I returned on wed from a trip and those parts arrived while I was gone. Please pm me your full name and address. I'll get this rolling out today.
Old Sep 5, 2008 | 11:22 AM
  #99
symalik's Avatar
symalik
done.
Old Sep 5, 2008 | 11:28 AM
  #100
finagle69's Avatar
finagle69
ditto.
Old Sep 5, 2008 | 11:43 AM
  #101
MaxToTheG37
Great... hope this shizzle works!!
Old Sep 6, 2008 | 01:09 AM
  #102
SFLG35's Avatar
SFLG35
FGC Central Florida BOD
alright guys i am goin to copy the post i just made on g35driver, about the same problem i am having. i have not read your entire thread so i dont know what has and has not been covered. here is what pete and i did all afternoon today:
alright guys i am hear to bring this thread back up to its original topic!!
today i finally made it over to bc in orlando from tampa, since i am the closest person to them that has had this problem, and i spent all afternoon from 4 to 9pm with pete at bc racing trying to get this figured out, why it was happening, and how we could solve it!!
i had the new rear spring setup for a few weeks and what gettin the knocking sound when i would hit a small bump in the road at a low speed. my knocking sound, sounds like it is coming from up high not at the spring!!
pete and i drove around so he could hear the nosie. we get back to the shop and take it all apart and check several things, one of them being the preload. since i had sufficent amount of preload we determined that was not the case.
so then we switched my rears to the old setup and went from the 10k spring to a 12k spring. we put those in and put it all back together, and went on another drive. knockings sound was still there, still sounding like it was up high and not down low.
get back to the shop, take it apart again and try to decide what to do next. we decided that the spring loaded adjusters sound like the could be making the noise. maybe from hitting the body of the car. so we take the adjusters off completely and go drive around again.
noise is still there, so we get back to the shop and take it all apart again. next we decide to look at the pillowball maybe that is moving too much and knocking on the allen heads on the inside, but we can not find any marks anywhere!! so since we have the upper plate off of the shock now, we think that hey maybe its moving around and bumping into the bolts. so we test fit it up and see that there is a lot of play in it, as the holes in the plate are larger than the bolts. so we found something that would fit snuggly around the bolt and inside the hole. luckily we found some thing and mounted the plate back up there, and it fit like a charm. didnt move at all, so we put everything back together and went for another drive. noise still occurs!!
once again back at the shop, we take it all apart. we decide that maybe since there is a small gap between the upper plate and the body that maybe its hitting there when going over a low speed bump and causing the noise. by this time it is now 9pm, so we decide to call it quits. pete is goin to look into getting some thin rubber like gaskets (like those that go on the upper spring mount between it and the car body) made to go between the upper plate and the car body, to see if this will solve the problem. hopefully it will!!
maybe you guys that are having the problem can look to see if you have a very thin gap between the plate and the body.
Old Sep 6, 2008 | 01:10 AM
  #103
SFLG35's Avatar
SFLG35
also for the person that asked if the kits were different, they are not.
the same upper plate is used on all 350z, g35, and g37 kits!! that is why it is weird that no 350z guys and very few g35 guys are having the problem, but there are several with g37s that are having the problem.
  #104
SFLG35's Avatar
SFLG35
in this picture you can see the little rubber pad at the top of the preload adjuster for the rear springs. this is what we are thinking might need to be added to the upper plate on the shocks. hopefully it will work!!
Old Sep 6, 2008 | 03:19 AM
  #105
symalik's Avatar
symalik
atleast some progress is made. A lot of stuff ruled out which is good! keep us updated
