2010 G37x Ballast Replacement - Please Help
Old Apr 5, 2023 | 08:02 PM
Slovewade's Avatar
Slovewade
I've tried everything and it's ultimately a ballast replacement that I need. The dealer is selling the whole headlight unit for $1500. Any suggestions on how to find a new passenger headlight unit? Or the ballast? I have a sedan. I accidentally ordered one for a coupe but it obviously doesn't fit. Any assistance is helpful.
Old Apr 5, 2023 | 09:07 PM
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
So, I would recommend just going to a wrecker. First though, could be your bulbs. Our ballasts HATE pretty much all D2S bulbs besides Osram, Phillips(OEM), and Morimoto. Some people have had luck with other brands here and there, but nothing consistent. I went through 5 sets of DiodeDynamics bulbs before they gave up sending me free replacements and I realized the problem was the bulbs, not the car. If its one side thats not working, try throwing the bulb from the other side in there and see if it works, easiest way to determine if it really is the ballast. The ballast comes with the headlight assembly, so finding and buying it separately can be tough unless you go with ebay or a local wrecker.
Alternatively, you can buy a DEPO headlight from rockauto for less than half that price the dealer is asking. https://www.rockauto.com/en/catalog/...assembly,10762
Old Apr 6, 2023 | 08:34 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Ballasts and bulbs are easy enough to replace- a hassle, but doable, plus they are interchangeable between models. There is absolutely no need to replace the entire headlamp assembly unless it is severely damaged (ie. wrecked).
What exactly are your symptoms?
TheDigitz
13
Nov 6, 2024 10:14 PM
Infiniterian
Nov 5, 2019 10:42 AM
JeisonG
Jul 2, 2019 12:22 PM
viclauyyc
Sep 10, 2017 05:39 PM
bmy986
Oct 11, 2014 09:11 PM
