Replacement HID Ballast
Old Jan 2, 2022 | 09:23 PM
TheDigitz's Avatar
TheDigitz
Looking for a bit of feedback on HID Ballast replacements.
My passenger side headlight has failed. I bought new bulbs from Diode Dynamics, but both replacement bulbs didnt fix the issue. I noticed the igniter(?) (whichever part screws into the light) wasnt hot while the lights had power, so I presume its the ballast. I will be checking the fuse before I order a replacement. If at all possible, I'd rather not replace both passenger and driver.
Here is what my research is turning up thus far.
https://www.headlightexperts.com/hea...11-Nissan-370Z - $79
https://www.z1motorsports.com/front-...st-p-9727.html - $100
https://www.z1motorsports.com/front-...t-p-21498.html - $71 - NOT OEM
https://www.headlightsdepot.com/hid-...-blb1-b74.html - $38
Anyone have experience w/ these ballast replacement options or elsewhere I should be looking? I'm presuming the cheapo headlightsdepo option isnt going to work well, similar to the cheapo Amazon options I'm looking at. Not afraid to spend a little coin, but would rather avoid the $230 OEM replacement cost if possible.
Old Jan 3, 2022 | 04:09 PM
Diode Dynamics's Avatar
Diode Dynamics
We recommend checking out HIDkitpros.com for assistance.
https://hidkitpros.com/product-category/hid/
John C.
Diode Dynamics
Old Jan 3, 2022 | 08:57 PM
TheDigitz's Avatar
TheDigitz
Excellent. Thank You! I'll give them a buzz
Old Jan 4, 2022 | 09:48 AM
mummy2's Avatar
mummy2
Just get the Z1 oem ballast. They're a legit company.
Old Jan 16, 2022 | 12:51 PM
TheDigitz's Avatar
TheDigitz
New ballast didnt fix the issue either. So now Im a bit confused. Any idea of what the issue could be at this point?
Old Jan 16, 2022 | 01:17 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Did you check the fuses?
Do any of the other light work (turn signal, city)?
Does the lamp (bulb) attempt to ignite (flicker) or is it completely "dead?"
Do you have a multimeter? If so, did you check for voltages at the harness connector?
Old Jan 16, 2022 | 01:36 PM
TheDigitz's Avatar
TheDigitz
i'm working on getting to the fuse box now. Found it and trying to pull it "up" - not going so great. Any guidance?
Turn signals work.
It is completely dead. I changed the ballast. I did not change the igniter.
The bulbs are 6k d2s, installed by previous owner. I have a set of 4.3k that I havent tried yet.
The ballast I went with is here : https://www.z1motorsports.com/front-...t-p-21498.html
Ordered two, figured I change both out since I had the car apart. I've tried both and no change.
No multi-meter. That is on the list after the fuse.
Old Jan 16, 2022 | 01:44 PM
mummy2's Avatar
mummy2
Assume you mean the box in the engine compartment. Just wiggle it and maneuver that thick a-s cord with your hand until it releases. It gets stuck on something sometimes.
Old Jan 16, 2022 | 01:54 PM
TheDigitz's Avatar
TheDigitz
Yup. Got it out. Confirmed is not the fuses. Also installed the 4.3k bulb and that didnt fix it.
So I'm thinking its an igniter at this point or a fault wire that I've not yet found. Or an alternative you guys may suggest.
Old Jan 30, 2022 | 10:28 PM
TheDigitz's Avatar
TheDigitz
Originally Posted by TheDigitz
... Confirmed is not the fuses. ...
Yea. I was wrong. It was a fuse.
I did install a new igniter, as I thought the fuses were good. Once that didnt work, started chasing electrical issue. Once I realized the ballast wasnt receiving voltage, i pulled the fuse box again and realized one of the 15 amp fuses were bad.
Still not entirely out of the woods. Even with new ballast, igniter and fuse, the light is flickering everyone once in a while. May go back to the 4300k lights and see if that solves the flicker.
Remember everyone, there are 2 sets (at least) of fuses for each headlight in that fuse box. Slow down and read - dont be me. Any learn to use a multimeter - I'd still be swapping random parts w/o it.
Old Aug 6, 2023 | 01:41 PM
xorbitman's Avatar
xorbitman
I'm having a similar issue with my 2012 G37xS Coupe. My passenger side Xenon turns off after about 30 minutes of driving. It turns off quicker and sometimes doesn't turn on in the cold. I recently changed the ballast and that didn't work. I swapped out the bulbs and this didn't change anything. So I will check the 2 fuses. Maybe I have a defective fuse? Also sometimes when I go over bumps that light flickers. I'm going to swap out the two fuses and check the wiring harness. I'm also going to consider switching to a plug and play LED conversion kit.
Old Nov 6, 2024 | 10:03 PM
Emily88888888's Avatar
Emily88888888
OEM ballast vs Original ballast
OEM ballast is 1:1, the same characteristics as your original ballast, aimed to meet even exceed the OE specifications but only a fraction of the price.
OEM ballast VS aftermarket ballast
OEM Ballast is generated from original ballast, with its aim to hands down the higher quality. But aftermarket ballast are for universal usage, RFI and EMI are the mostly caused problems.
Old Nov 6, 2024 | 10:12 PM
Emily88888888
How Do I Know if My Ballast is Bad?
Physically.Look for the following signs on your ballast first. If you see any of them, then most likely, your ballast needs replacement.
Burn marks
Swollen or melted casing
Damaged or perforated case
Old Nov 6, 2024 | 10:14 PM
Emily88888888
Burn marks
iCrap
46
Jan 29, 2017 06:34 PM
pwcracer
Dec 19, 2016 04:35 PM
J_comb
General Tech Questions
May 12, 2016 01:08 AM
Jackooze
Dec 24, 2012 06:48 PM
_ant_
Jun 25, 2011 10:54 PM
