illuminated kickplates
Old Mar 1, 2021 | 03:32 PM
woodieg37's Avatar
woodieg37
My Passenger side illuminated kickplates light is Flickering. Driver side is fine. Do I need to replace the illuminated kickplate or is it just a bulb going out? I try to remove it but think it’s Held on by clips and double sided tape?
Old Mar 2, 2021 | 03:05 AM
BeeW's Avatar
BeeW
Whole plate needs to be replaced. The bulbs are embedded in the plastic. Terrible design imo
Old Mar 2, 2021 | 09:04 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Technically, once the LED's start to flicker it won't be long before they crap out entirely. If you have the time, skills, AND patience, you can replace the LED light strip, but be warned: it is not a easy job. Not hard, but a royal PITA. In the end most just find a used plate from a junkyard or eBay- much easier to replace than repair.
This thread has some useful pics and info.
Old Mar 2, 2021 | 09:26 AM
woodieg37's Avatar
woodieg37
Mine has been flickering for about a year now just after I bought the car it started. Thanks for the info, and that other thread is helpful. I searched but that one didn’t come up for some reason
Old Mar 5, 2021 | 12:00 AM
Aurieg's Avatar
Aurieg
Guys, I bought a set of these kick plates from ebay for my g coupe however, it did not come with a BCM harness. Just two plates and nothing else. I have a dilemma on my hands, I don't know which two wires to splice them into. Could you maybe look at yours and see where positive and negative connect to? Attached is an image of the plug in question on the pass side in the footwell.
Old Mar 5, 2021 | 09:01 AM
ILM-NC G37S
Originally Posted by Aurieg
...I have a dilemma on my hands, I don't know which two wires to splice them into...
Easy as pie. Here's what I have:
This is from the kickplate installation guide:
(pdf can be downloaded from this pdf link).
This DIY thread shows exactly what you are trying to accomplish.
FWIW, the T-Harness, while it makes for a easy "plug-and-play" install, it is a PITA to deal with because there is no free space. Just make sure your taps are secure and wrapped in electrical tape.
Old Mar 5, 2021 | 11:34 AM
Aurieg's Avatar
Aurieg
Thank you so much! By the way, I just got my grill and trunk trim from the paint shop, gloss black.
Old Mar 5, 2021 | 11:44 PM
Joyryde's Avatar
Joyryde
Really easy to do. Just don't bend the metal plate. The only hard part was assembling everything together so the metal would not pop up from the plastic. That just required some strong epoxy glue and letting it sit overnight. Buying new ones weren't an issue for me, I just wanted to experiment and it worked.
All G'd Up
May 18, 2017 02:14 PM
fgxmfmq
Jan 16, 2013 08:32 AM
dweiss22
Jun 18, 2012 12:08 PM
Shane D
Jan 28, 2010 11:07 PM
rmklaw1
23
May 23, 2009 07:39 AM
