Issue: Car confused if door is closed
Old Jul 14, 2020 | 03:32 PM
Que60's Avatar
Que60
I have a 2015 Q60S. After opening the driver's side door, the car seems to be confused whether the door is open or closed and rolls the window up/down slightly repeatedly. Has anyone else experienced this? If so, please share the fix.
Thank you in advance for your help!!
Old Jul 14, 2020 | 05:53 PM
ILM-NC G37S's Avatar
ILM-NC G37S
I would start by checking the door jamb switch. Open your door and look for this switch (it will be on the right side near the door latch):
There should be one Phillip's head screw. Make sure it is tight. You could also remove the switch and make sure there is no corrosion. Again, make sure the screw is secure. You won't hurt anything. If the problem persists, then you'll have to dig deeper.
2015, no more warranty?
Old Jul 14, 2020 | 05:59 PM
Que60's Avatar
Que60
Thanks for the tips! I will give them a try. I bought the car as a certified pre-owned and the warranty expired in April
Old Jul 15, 2020 | 11:20 PM
Que60's Avatar
Que60
I took it a part like you suggested, super simple. Seems like it was getting stuff and not fully expanding out. I hit it with a little bit of WD40 and exercised it for a bit and did a little more WD. Seems to be back to working order, thanks for your help!!!
Old Jul 16, 2020 | 08:33 AM
ILM-NC G37S
Glad you got it sorted. Sometimes the smallest things can be the most annoying...
G37xMN
Feb 25, 2020 10:25 AM
CRiME
Nov 16, 2014 01:38 PM
redcoupe
Feb 15, 2014 02:15 AM
gtracing
Jan 17, 2009 07:20 PM
